Help!! kickdown cable (shifter cable)
hanley1732
I've bought my first bronco and couldn't be more excited! That was until my local auto shop told me it needs a kick down cable or shifter cable and they have been discontinued!! its a 1988 ford bronco and I have waited so long to pull the trigger for this to happen breaks my heart... any help? any ideas? part # F2TZ-7F042A
yo Hanley,
WELCOME!
You probably have an AOD in your 88?
AOD have 14 pan bolts, see diagram & pic; P-R-N-(D)-D-1 shifter pattern, note, OD is actually a (D)
shift indicator pic by trigger @ http://img.photobucket.com/albums/v663/RampageFSJ/a4-1.jpg
Shift Linkage Adjustment & Diagram
Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy) at http://ylobronc.users.superford.org/documents/shiftlinkage.html
Parts Break Out Diagram
Source: by Steve at http://www.supermotors.net/vehicles/registry/media/203172_1
Throttle Valve (TV) Adjustment; Using a 100 psi pressure gauge to the TV port on transmission (This has to be done when needed instead of guessing https://web.archive.org/web/20070616041418/http://tciauto.com/Products/Instructions/instructions/431000_inst.htm
C6 have 17 pan bolts, see diagram & pic; P-R-N-D-2-1, shifter pattern)
To get accurate info when posting Qs, soon in your profile, include your year, Model (XLT, etc.) engine size; transmission, transfer case, locking hub types and any major mods such as body or suspension lift.
Left Click your name in upper right corner; in pop-up left Click on My Profile
Below an Ad, in right side. Left Click Edit my Profile
In Left Side, Left Click Change Signature
