Electrical Issues
specialized187
Hey Guys, need a little help. I recently updated my front clip from a 87 body style to a 93 body style, in the process of the conversion, I must have done something to a ground or relay cause now I cant get the motor to fire. I noticed that the fuel pumps wont come on when I turn the ignition key to the on position and replaced that relay and the same problem is there, checked the rollover switch to see if it was tripped, sprayed starter fluid in the intake manifold and got it to fire, but dies, so i have spark just no fuel going to the injectors. Can you guys throw me a bone to head me in the right direction.
Thanks
The circuit is pretty simple, here is a diagram to help troubleshoot.
