Throttle Position Sensor
Ryan S.
I  have a 1989 Bronco 5.0L AOD, the past week the engine would rev up and down on its own and  idle high. I figured it’s the tps sensor, when I tested it(with digital multi meter grounded to the battery I used a needle stabed through wire so I could get good reading) I was getting 32 MV at idle and it would jump around when I move the throttle, when I tested the orange wire I got 5 volts, and when I tested the green wire (red wire from meter to positive on battery and ground at wire)I only got 8 volts. So is it the TPS or something else? and the motor will some times feel like its low on power and have hesitation and when I step on the gas to pass or drive up a steep hill the engine hesitates  and there are no check engine lights.
yo Ryan,
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
Some basics;
Do KOEO test First
KOEO
KOER
TPSTesting in 5.0 & 5.8; "...Symptoms of a BAD TPS: The one thing that you can definitely count on, when the TPS fails, is the Check Engine Light shining nice and bright to let you know that there's a Diagnostic Trouble Code stored in the Fuel Injection Computer. Here are some specific symptoms you'll see: 1.TPS Diagnostic Trouble Codes: (DTC’s) stored in the vehicle’s computer’s memory. Code 23: Throttle Position (TP) Circuit Performance Problem. Code 53: Throttle Position (TP) Circuit High Input. Code 63: Throttle Position (TP) Circuit Low Input. Code 121: Throttle Position (TP) Circuit Performance Problem. Code 122: Throttle Position (TP) Circuit Low Input. Code 123: Throttle Position (TP) Circuit High Input. 2.Really BAD gas mileage. 3.No power as you accelerate the vehicle. 4.Hesitation when you step on the Accelerator Pedal. There are times when the ECM (Electronic Control Module = Fuel Injection Computer) will think the TPS has failed when it hasn't. This usually happens when the ECM spits out several Diagnostic Trouble Codes at once.. and so what will save you time, money and the frustration of replacing good parts, is to test the Throttle Position Sensor..." READ MORE
Source: by http://easyautodiagnostics.com/ford/4.9L-5.0L-5.8L/throttle-position-sensor-tests-1
Lotus
Norway
I had a problem with my TPS sensor. It came up on the KOER codes. Its the easy way to test it. ;) /emoticons/[email protected] 2x" width="20" height="20" />
danno
