ColtonAndrew
- Joined
- Jul 10, 2014
- Messages
- 13
- Reaction score
- 0
Hello!
Recently, I took my b2 offroading.. literally off all roads and into a creek. Water never got up to the doors but it did splash quite a bit of water all around. I made it home with absolutely no issues (20 miles from location) and parked it over night. I woke up and went to run some errands when I came to find it wouldn't start. I tried clutch starting and dry runs, nothing. It does try to turn over though, but it's acting like it's simply out of gas.
I let the car sit in the hot kansas sun for 2 days with the relays opened to allow them to dry (they were sopping wet)
I got to work on testing things, first I checked the Fuel Pump Relay and all wires read hot when they were supposed to, so I went on to replace the relay. No luck
From there, I checked the wires for damage, nothing but occasional cracks in the tubing. The eec and all other relays are good.
I did notice my inertia switch might have maybe been tripped, its button is slightly raised. So I smacked it with a crowbar and fully tripped it, reset it, no change.
Then I thought I'd listen for the fuel pumps (high pressure on the frame rail and low pressure in the tank) and the high pressure kicks on but not the low pressure.
This got me onto the idea of a bad connection, either in the plug or ground. I searched for the ground for about half an hour until I lost all my daylight.
Does anyone have an idea of where the ground is located or what else might be causing this issue? My wire cluster come from the plug in the tank directly into a sleeve and from there it adds more wires until ending its journey in the engine bay. No cords go out, only in.
https://www.facebook.com/photo.php?v=1512024155684052 This is a video or me getting it wet. I did this for almost an hour, on top of trails and actual creek runs.
SOLVED!! After many issues, it was my starter solenoid. Read the posts below for all the trial and error and troubleshooting.
