1991 bronco rear window key switch
Megabronco91
kentucky
Have had my bronco for 7 years now and would like to finally get my rear window key switch working. Wiring is connected with no corrosion I think it possibly the box the is actuated by the key is the cause if anyone can tell me the name of the part or where to get one would be great
I assume it works from the driver switch. Are you aware that there are 2 fuses that provide power to the tailgate window?  Diagram attached.
If it works from the driver switch you are probably missing 12V on the black and white wire located on the tailgate switch.
PS.  If someone has ever removed the tailgate switch, they may have neglected to properly reinstall the actuator arm on the end of the key cylinder that actually activates the electrical switch part of it.
heinrich
