Bronco Graveyard 6" Lift Review
navybronco23
Milton, FL
]Hey everyone. I wanted to offer up a quick review of the lift components I ordered from Bronco Graveyard in case anyone is currently shopping around. I went with this option because I already had a shackle flip in the rear so I did not need the rear lift items. Here is a list of things I bought:
33510 80-96 5.5" Extreme Coil Springs, CSF64,       33660 Sway Bar Drop Brackets, Pair,       33144 Axle Pivot Bushings,80-96 4wd (Pair) ,       33518 JBG Drop Pitman Arm, (4" or 6" Lift) 80-96,       33114 Sway Bar Bushings, Front, Red 1" Diameter Bar,       33516 Front Bracket Kit With Extended Radius Arms, and       33015 Radius Arm Bushings Repair kit 1985-96
First off, everything I ordered arrived quickly and safely. There were no missing or incorrect pieces. The instructions were clear and most of the pieces were from BDS so they were hefty and well built. In addition I ordered Bilstein 5165's to replace my quad shocks with a single shock setup.
The installation was as straightforward as possible and all of the components fit as advertised. After throwing some new shoes on the truck and a much needed alignment she handles and drives like a dream. I would recommend this lift to anyone who wants to avoid buying a full lift kit that doesn't allow for customization.
Before:
The Kit
Install
After:
yo Navy,
Thanks for posting up the in-depth review.
Your info will help others on their Lift source decision.
digs
