wont take off in drive
duckkiller91
hey guys need some help.
I recently bought a 93 bronco. 5.0
it wont take off in drive. I have to put it in 1st or 2nd and when I gain a little speed throw it in to drive and it will work but as soon as I drop my speed to about 15 or so it goes out gear and I have to put it back down to 2nd  or 1st.
so what would cause this?
plz help me out.
thanks
yo D,
WELCOME!
try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?&pid=74587&mode=threaded
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Do Key On Engine Off (KOEO) portion first..
And Post em here according to:
KOEO
KOER
93 Bronco-Econoline-F-Series Workshop Manual by FORD
https://www.motorcraftservice.com/pubs/content/~WSPM/~MUS~LEN/21/SPMLEFT.HTM
go to;
Section 07-01A: Transmission, Automatic, E4OD
Electrical/Hydraulic/Mechanical/Diagnosis Charts
https://www.motorcraftservice.com/pubs/content/~WSPM/~MUS~LEN/21/SPM71A18.HTM
D
duckkiller91
thanks dude. I appreciate it. that was a bad ass link will try it as soon as I can and will post back
D
duckkiller91
alright came to find that there is vacuum leaks and hoses missing.
can anyone post a vacuum diagram or a link to one that would be awesome
thanks
I don't have one, but there should be one under the hood.  Usually it is located on the radiator support or on the underside of the hood.
yo DK,
Get your Vacuum Diagrams & Calibration Parts List in the Vehicle Emission Control Information (VECI) Decal, for 88 & UP.
On-Line for Free at Ford.
Click "Quick Guides" in left panel;
Scroll to & CLICK VECI Labels "Provides Vehicle Emission Control Information (VECI) and a related calibration parts list."
Enter applicable info (need to know your Calibration number from your B-pillar sticker).
Vacuum Diagram is the same as the one on the core support or hood or air filter cover.
Source: by Ford @ http://www.motorcraftservice.com
This diagram does Not include the HVAC sys vacuum operated doors, etc.
"...In 92-96, The air handling system is designed to provide defrost when no vacuum is applied to any of the three air door vacuum motors. This is done to prevent a situation where defrost cannot be obtained due to a system vacuum leak. Instead, a leak in the vacuum control circuit will send all airflow to the defroster outlets. This condition may occur during acceleration (slow leak), may exist at all times (large leak) and may happen only when certain specific functions are selected, indicating a leak in that portion of the circuit. ..." from F-150, F-250, F-350, F-Super Duty and Bronco, F-Super Duty Motorhome Chassis Workshop Manual
Source: by Ford;
HVAC Vac Diagram in 92-96
Vacuum Line leak test, Acronyms & gauge pic
http://broncozone.com/topic/23994-90-58l-getting-continuous-code-33-and-running-code-44/
see Post #20
D
duckkiller91
got hold of a diagram...
but when I went to the site It didn't have my calibration.
and I thought I might have read it wrong but it wasn't there and I tried it for different years too and it wasn't on there.
but I got one.
there is 1 hose missing and 1 that has a big hole in it, so I will fix that and then I will try the self diagnostics.
thanks miesk5
yo D,
great!
Ford issued this TSB for 92 Broncos, etc.
EEC IV 5.0L 49 State & High Altitude Calibration Conversion (EEC IV Processor Change) TSB 92-16-9 for 92 Bronco, Econoline, F 150 & F 250
http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=35160
It is a pdf file
Ford knew they were discontinuing Bronco production in 96 so  they often did not update TSBs for following years.
see if your Cal # is in this TSB for future use such as Part Numbers.
Utahstroke
