manual to power steering conversion kits
project71
Recently purchased 71 Bronco and want to install a power steering system. Has anyone used any of the kits available from the many suppliers? I am fairly handy with wrenches but I am not a "mechanic", so what should I look for and what should I avoid?
I've done several of these..,  They all (kits) work well.  The easiest is the one that uses the STOCK holes in the frame.
Meaning no drilling.
Simply remove the manual & install the power box.  (ahh., they're quite heavy.)
Wheels straight ahead when removing the old box. Center the new box shaft upon installing the pitman arm.
(some go on with a flat spot on the shaft so there's no mistake.)
The brackets & pump mount to the eng. ..., pretty simple. Hoses have dedicated attach holes.
The pullies are a bit more work but very doable. along with re-installing the belts.
I unbolted the steering column & tilted it down enough to get the "long" steering shaft out.
(pulled upward & into the cab)
Some time involved but didn't want to cut it. (there's bearings & felt seals of sorts at the steering
wheel & at the bottom of the column. Watch for them, clean them & put back in the same order.)
The NEW upper & lower shafts & u-joints come with most kits. Pricy but well worth it.
With the shaft & orig. box pulled, install the new shaft first. (this way, the pump won't be in your way.)
You'll have to remove the radiator shroud to R&R the pullies/belts.
Prime the pump with the wheels off the ground.
It's a "2 banana" job.., take your time & cleanliness is important.
 ---- The second time you do one, it's  REAL EASY..! ^_^ /emoticons/[email protected] 2x" width="20" height="20" />
Sgariffo
