yo V,
WELCOME!
Lets, go through the Codes before suspecting the ECM (aka PCM, computer, EEC...);
DTC 121, 122, 123, 124, 125 & DTC P0122, P0123 & P1121 in TSB 94-26-4; "...The following is a list of vehicle symptoms which have been associated with the TPS, but can also be related to other vehicle components. Check engine light, Stalls, quits, hesitation/stumble, fast idle; To minimize the replacement of good components, be advised that the following non-EEC areas may be the issue: Excessive blow-by, PCV malfunction, Vacuum leaks, Fuel pressure, Throttle sticking or linkage binding. MANY VOLTMETERS WILL AUTOMATICALLY CHANGE RANGES WHEN MEASURING TPS OUTPUT FROM IDLE TO WOT. WHEN A VOLTMETER IS USED TO MEASURE TPS OUTPUT FROM IDLE TO WOT, THE METER SCALES OR CHANGES RANGES AUTOMATICALLY. THERE MAY BE AN ERRONEOUS METER DISPLAY UNTIL THE VOLTMETER HAS LOCKED TO THE APPROPRIATE VOLTAGE READING. THE ERRONEOUS METER DISPLAY DOES NOT REPRESENT A DEFECTIVE TPS. NOTE: IT IS RECOMMENDED THAT THE "RANGE LOCK" FEATURE ON MANY METERS BE SET FOR CHECKING TPS VOLTAGE..."
Source: by Ford via
http://www.tccoa.com/articles/mn12-techinfo/tsb/tsb-94-26-4.pdf
Throttle Position Sensor Testing, Replacement and Adjustment
by
Seattle FSB
DTC 116 Engine coolant temp. higher or lower than expected Possible causes: Low coolant level (ECT), Ambient temperature below 10°C (50°F) (IAT), Faulty harness connector, Faulty sensor
Source: by fordbronco1995
DTC 116 to 118 ECT Troubleshooting & Possible Causes; "...The ECT sensor is a thermistor, basically a resistor that changes voltage accordingly to temperature changes. It provides a reading that's used by the EEC to change fuel delivery at engine startup to reduce emissions and monitors the temperature of the engine. If you see some rust in it clean it by sanding the surface using a fine grit sandpaper, Also check the connector and wiring..."
DTC 636 Transmission Fluid Temp (TFT) higher or lower than expected; "...Can be caused by a bad connector or harness (an open circuit, or short to Ground / Batt), or the transmission was overheated. Once you remove the pan locate the sensor in the valve body and remove the electrical connector very carefully. The sensor is about the size of a pen cap. To remove the sensor carefully unlock the stop tab and twist it, pull down to remove it. It comes out before a full quarter turn is made. Put it back in the reverse order. When you get the sensor to come out be prepared to catch the trans fluid that follows behind it, you will get less than a quart out of it. It is located in da Pack between Converter Clutch Control (CCC) Solenoid & the Coast Clutch Solenoid. try the connections first. They are usually the root of the problem..."
DTC 112 to 114, Intake Air charge temperature sensor (ACT or IAT)Troubleshooting & Possible Causes; "...Codes 112 to 114 will set a IAT sensor code in the EEC, remove and inspect the sensor it could get contaminated by engine oil , K&N oil or dust. Clean the sensor with isopropyl alcohol. If the sensor still fails replace the unit..." Intake Air Temp (IAT); (Air Charge Temperature [ACT] prior to 1992)
"This measures the temperature of engine, and has a great impact on fuel ratio. This makes simple work of enriching the mixture on start up, overheating, and full throttle fun. It also allows us to lean out the mixture at certain times, to shorten the time it takes to warm up the engine helping us get great fuel economy. The Engine Coolant Temperature (ECT) sensor is a thermal transistor, which means it allows less electricity to pass through the sensor the warmer it gets. The ECT receives the “Signal Return” voltage from the EEC, then allows a certain amount to return back to the EEC. Because the ECT is in direct contact with the engine coolant flow it changes resistance in response to the temperature of that coolant. The ECT is third in command in the hierarchy of EFI sensors, this means this sensor is very important when calculating fuel ratios and timing curves. This is because of simply chemistry; fuel and spark are constants in the equation. Air is the biggest variable in combustion; it changes density greatly over a range of temperature. So keeping track of the changing temperatures of the incoming air and the engine in which it is burnt becomes very important. But due to its simplicity of design, the ECT is rarely at fault when problems occur.
The engine temperature must be greater than 50°F (10°C) to pass the KOEO Self-Test and greater than 180°F (82°C) to pass the KOER Self-Test. To accomplish this, the engine should be at normal operating temperature...Before you start blaming the engine coolant temperature sensor and replacing it make sure the rest of the coolant system is in good condition. All of the following items will affect the ECT: *Coolant level *Radiator Fan *Water Pump *Water Pump and Fan Belts *Thermostat *Base Timing *Engines general condition *Harness and wire general condition..."
Source: by Ryan M (Fireguy50)
Consider Ford Fuel Injection and Electronic Engine Control: How to Understand, Service and Modify, 1988-1993; & Ford Fuel Injection and Electronic Engine Control: How to Understand, Service, and Modify All Ford-Lincoln-Mercury Cars and Light Trucks, 1980 to 1987 by Charles Probst
avail @ BARNES & NOBLE, AMAZON, E BAY, ETC.
