Oil Pan Bolts
pj31704
Texas
Does anyone happen to know if all of the oil pan bolts should be 5/16-18X1 7/8? Looks like whoever put mine in previously used a few different bolts. Are there a few that are a different size?
Geeese..., you'd think someone else would chime in & advise ya., looks like you're stuck with me... >:D< <'>  :lol:
If memory serves, there's stiffeners at the front-n-rear of the pan.
If so.., there's likely four (maybe more) bolts that are longer than the rest. The longer ones go with the stiffeners.
Some go up into the T-chain cover & likely longer.
As a general rule..., always make note of where bolts came from on disassembly. Many parts have diff. bolt requirements.
pj31704
pj31704
Texas
Thanks for all the help Bully Bob! Just about got the rig back together, wouldn't have been able to do this repair without your help!
You're quite welcome.., glad to help.
I think we set a record as to the number of back-n-forth posts gett'n you thru this project. ^_^ /emoticons/[email protected] 2x" width="20" height="20" />
As I said B4, there are quite a few folks viewing your questions so we likely helped a few others do, or at least
think about doing these projects.
By doing this "hands on" project, you'll have learned some techniques you can transfer to other projects if necessary.
Don't be a stranger.., check-in often as you may be able to help others.
Have fun out there..,
Bob
pj31704
pj31704
Texas
I am almost finished, however I am having trouble getting clearance to install the oil pan. I need to remove this bolt in order to make some room, does this bolt just come right out? I have tried but it won't budge.
pj31704
pj31704
Texas
Having trouble keeping the rubber gasket ends in place while installing pan. Anyone ever had trouble with this? They keep sliding out of place when I try to get pan positioned correctly.
Sgariffo
