86 bronco xlt
86choppedbronco
got a 86 bronco last weekend ran fine all day parked it was going to take my girl friend for a ride  an wouldn't start til next day anyone know why it may have done that?Did a lil rust repair on it have a 1981 clip an doors bout to be put on it maybe this weekend
Welcome to the Zone !! Looks like you are going to have some fun working on the body.  If you are going to repair the body, you might consider new fenders and 1/4 panels.
Need a little more information, like what engine is in it?  When you try to start it, does the engine turn over but not run?
yo 86, WELCOME!
As Seabronco advised; in your profile, include your year, engine, trans, Xfer case & locking hub type (auto or manual) and any major mods such as body or suspension lift, etc. or in any question post. You'll get more accurate replies
Left Click your name in upper right corner; in pop-up left Click on My Profile
Below an Ad, in right side. Left Click Edit my Profile
In Left Side, Left Click Change Signature
Also is the Check Engine Light on while driving?
and it should light up when first starting the Bronco
 the Self-Test
To check for codes without buying a code reader is simple. If your EEC is wired correctly, the engine light works, and there are not any electrical faults in the vehicle you can get the codes out of your EEC.
http://oldfuelinjection.com/?p=13  by by Ryan M (Fireguy50) http://oldfuelinjection.com/?p=13
post any codes found here.
Self Test - & Connector Location Video in an 86; "...My Test Connectors and Battery are on the "right side" (passenger) behind a black EGR Vacuum Reservoir..."
Source: by JKossarides ("The Bronco", Jean) at http://www.supermotors.net/registry/media/783663
AlaskaExus
