Correct Harmonic Balance
pj31704
Texas
I am having trouble finding the correct harmonic balance for my truck. I have looked around and the closest I have found is on Jeff's. However the one they are selling has 5 holes drilled in the outer ring, mine only has 3 holes drilled in it. Does anyone know if this would be the correct one or if there is one somewhere else. Thanks
http://broncograveyard.com/bronco/i-10412-harmonic-balancer-302-1969-77-new.html
To my knowledge, those are balance holes drilled in to balance (or the lack of) the unit at the factory.
Meaning the harmonic balancer is actually "out of balance" until it's attached to the crank.., then the two together
come into balance.
Most all EB stores have them.
Sgariffo
