C4 Trannie leak....
genthree
Medford, OR
Anyone ever had a C4 leak right where the shift linkages enter the housing?  I was down removing my Neutral safety switch and noticed some fresh fluid on the ground and fresh fluid on the linkage and nut....
yo
This manual may have torques, etc in it;
  1973 Ford Truck Shop Manual, Five Volume on CD # 19927
New
1973 Five Volume Ford Truck Shop Manual
Covers Trucks and Broncos
This is a CD for your computer not a book.
Price: $35.00
http://broncograveyard.com/bronco/c-756-repair-manuels-on-cd.html
This is a NON-RETURNABLE ITEM.
  Give em a call and ask; but I have called and e mailed Jeffs a few times and never got a reply on other products; even had the BZ manager e mail Jeff imself to ask, but got back zip.
Bwonco
There is a lever seal and an o-ring that can leak in that area. Try replacing the o-ring first because it's the easiest. 1/2" wrench, remove kick-down lever and the o-ring is right there around the shaft.
If it needs a manual-lever seal, that requires removal of the valve body to access the 7/8" nut holding the lever on.
Utahstroke
