HI
I have a 1978 Ford F150 Lariat and i am trying ot bleed the brake system. For some reason i can not get the rear brakes to bleed. There does not seem to be Fluid running to thm i have removed the bleeding valve to check for possible malfunction or blockage and even with the valve removed fluid is not flowing. Any ideas would be Massivly welcome
thanks
thanks
