ok
To begin with this is as built;
from
Section 14-00: Battery and Charging System, Service
1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual
DIAGNOSIS AND TESTING
Electrical Schematics
Charging System, Gasoline
This is by Painless
http://www.painlesswiring.com/Manuals/40102.pdf
It is diff than the 4WD Systems Intelligent Isolator diagram I showed in prev reply
So, if you know the isolator brand, it will help id what diagram to use.
excerpt; "
Connect your winch positive power cable to the main battery. This is to allow the alternator to
power the winch along with the main battery when in mode two (2). Winching in mode two (2)
will hold the auxiliary battery in reserve for jump-starting. This is important if you stall the motor
or turn the key off after winching without allowing the main battery to recharge.
Note: It is best
to run the engine 5 to 10 minutes after a winching operation to recharge the main battery.
Connecting the winch to the main battery is opposite from all other dual battery systems. When
using the Cirkit Boss Good Samaritan Dual Battery System you must connect the winch to the main
battery for optimum winch operation.
Stereos and Amplifiers
Connect your car radio and amplifiers to the stock, main, battery. This will allow the system to
turn off with the key. By connecting the stereo in this manner you will make sure that the stereo
will not drain the main battery by being left on accidentally when exiting the vehicle. Always
connect the stereo to the accessory side of the key..."
To post a pic from your PC, look below @
Attach Files
has a paper clip depiction to the left
Max. single file size: 750MB Click on Choose Files find the pic you want to post...Have to go through this myself since we have an updated forum now/
then Add Reply
