yo broncostyle,
What year and engine?
Also did you contact these firms?;
Jeff's Bronco Graveyard - Nylon Fuel Line Connector Repair Kit 90 Degree; Nylon Fuel Line Connector Repair Kit Straight W/Union; Nylon Fuel Line Connector Repair Kit Straight /16" Quick Connector, Straight w/ 18" of 3/8" Nylon Tube and a Union
http://broncograveyard.com/bronco/c-1511-straps-parts.html
Inline Tube - Bronco/Ford truck pre-formed brake, power steering & transmission cooler line sets, hoses, fittings, & rubber fuel hoses, etc.; exhaust systems; parking brake cables; gas tanks, etc.
Call them since not all parts are shown on-line Inline tube exclusively CNC manufactures all the hard to find fittings. If your original fitting has a long hex, deep thread, or any kind of special feature, you can be assured we will have an exact replacement on your line. Inline Tube DOES NOT substitute generic fittings on any line. Spring wrap (armor guard) and black cloth wrap is also installed in the same locations as your original lines. Inline Tube makes tubing products in the following sizes: 1/8", 3/16", 1/4", 5/16", 3/8", 7/16" and 1/2". The stainless tubing features a bright unmarked finish and the steel tubing is coated with a tin/galvanized rust protection just like the OEM original.
http://www.inlinetube.com
FMSI - air conditioning, brake & fuel lines & fittings; Bronco/Ford truck door hinge pins & striker bolt assy; mini blocks & pins & terminals, pig tails - Ford / Chrysler repairs, rusted and leaking fuel lines
OEM style flare with viton O-ring (Brown)
http://catalog.fmsiinc.com/viewitems/repair-lines/steel-fuel-repair-lines?&bc=100%7C1002%7C1059
http://www.mypartshop.com/
Select;
All Parts
year, etc, then FORD TRUCK
Fuel Lines
Zip Code;
my Comcast is dead slow again so, I was timed out, but got one hit;
92
BRONCO Fuel Lines
5.0 04-92 0 130015
78575 0.0 Call 1881 Call Oregon & A to Z Auto Wrecking
503-653-8181
800-769-6893
Dan
503-653-8181
800-769-6893
1209 SE 190th Ave
Portland OR 97233
[email protected]
or
http://www.copartfinder.com
Has Vehicle Pics!
http://www.picknpull.com
http://www.car-parts.com/
Also for obsolete parts;
Our Sponsor here has been adding some to inventory; Jeff's Bronco Graveyard
and: by Ford pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
Also; fyi & Posterity;
Nylon Fuel Line Service Procedure TSB 92-12-16 for 86-92 Bronco, Aerostar, Econoline & Ranger; 91-92 Explorer; 85-92 F-150-350; 88-92 Super Duty; 86-90 Bronco II
Source: by Ford via Chilton
http://content.chiltonsonline.com/TSB/displayTSBHandler.ashx?assetID=36152&key=6kAUBD5BruOJf%2f3tgozUqjXM3RdbjcQqW4sVWiE%2fp2IojfpfKqM07dr61%2bQAWHtTJ1N7Mgu3AvSabLSypE3tQGB%2fp0cZmt8BpRktsy43U1h5CUze4jzam8KItXnQTE0cEhIQpMOJySNYo4EjAyn0Vw%3d%3d
