1978 chassis layout
mausome
Were can i find a chassis layout of a 1978 Bronco? Stripped the frame a couple of years ago rivets and all. Would like to bolt it back together, any help would be much welcomed.
yo mausome,
WELCOME!
Until someone else can post better info;
Here is a Body Mounts Parts Break-Out Diagram in a 78 w/Nomenclature
Source: by Indybronco (Lula Mae)
btw, Indy has more 78 diagrams of diff components @ http://www.supermotors.net/clubs/superford/registry/1964/33106
Incl., for example (Left click on diagrams to Enlarge)
Fuel Tank Parts Break-Out Diagram in a 78 without Nomenclature
Source: by Indybronco (Lula Mae) at
http://www.supermotors.net/clubs/superford/registry/media/306875_1
also shows fuel line clips locations on rear frame
Rear Suspension Parts
http://www.supermotors.net/clubs/superford/registry/media/307055
Leaf Spring Shackle Bracket to Frame, Shock Bracket, etc.
Front Suspension Parts
http://www.supermotors.net/clubs/superford/registry/media/307054
Bucket Seat Tracks
http://www.supermotors.net/clubs/superford/registry/media/307051
Steering Gear Box
http://www.supermotors.net/clubs/superford/registry/media/307048
NP205
http://www.supermotors.net/clubs/superford/registry/media/307047
NP203
http://www.supermotors.net/clubs/superford/registry/media/307046
engine mounts
http://www.supermotors.net/clubs/superford/registry/media/307024
sheet-metal-rear
http://www.supermotors.net/clubs/superford/registry/media/306878
includes floor pan to frame crossmember; not a good detail though
fender
http://www.supermotors.net/clubs/superford/registry/media/307028_1
some pics may help in;
1978 Ford Bronco Frame build up by 1978mudweiser
http://www.supermotors.net/clubs/2bigbroncosrockymountain/registry/16387/55420-2
Body Removal pics in a 79
Source: by sfu7274456 at http://rmftc.com/forums/showthread.php?t=5287
Following by Chilton;
78 Bronco FRONT SUSPENSION
parts diagram;
REAR SUSPENSION
Steering Gear to Pitman Arm Parts Break-Out Diagram in a 78 w/torque specs
http://content.chiltonsonline.com/content/images/8576/images/85768076.pdf
Source: by Chilton
Radius Arm Installation, James Duff in a 78
Source: by Slim C (MTN BOUN) at http://www.supermotors.net/clubs/superford/registry/media/576649
Slim shows frame area @ RA
C6 Cross Member Info & pics in a 78
Source: by Steve J (Steve) at http://www.supermotors.net/registry/15145/53708
Transfer Case -> New Process
205 Exterior Parts Break-Out Diagram in a 78 w/Nomenclature
Source: by Indybronco (Lula Mae) at http://www.supermotors.net/clubs/superford/vehicles/registry/media/307047_1
203 Exterior Parts Diagrams; Shifter Assembly, Mounts, Transmission Adapter, etc.
Source: by Indybronco (Lula Mae) at http://www.supermotors.net/clubs/superford/registry/media/307046_1
And to Save you $, this book by Ford does not show the Bronco frame, and that is surprising
Standard catalog of 4X4s
Robert C. Ackerson
http://www.supermotors.net/getfile/794253/fullsize/dsc03866.jpg
M
mausome
Thanks alot! That's want I was looking for...Thanks again
jobronco64
Great info!  My 1978 has the "handling package".  This included dual front shocks and a rear steering stabilizer.  Haven't been able to find a diagram of that.  Anyone know where I can find one?
yo I think this is the
78 Bronco quad shock diagram from Haynes Manual 36058 (880) - red cover;
figjeti
