I need HELP. I am new to 4-wheeling and therefore i don't have much savvy on 4x4 parts. I have a 1968 bronco with a small block 351 and 4-speed. My 4-speed is junk and i want to swap to a Ford c-6 automatic and still use my Dana 20 transfer case. I don't want a high dollar, bullit proof, custombuilt transmission - i do need information on what 4x4 junk yard transmissions that would work (Ford small block remember) without having to buy a $600 adapter. Or, if i do have to buy an adapter, is there a less expensive one somewhere? Second option; a small block Ford c-6 complete with transfer case that would fit inside the narrow frame rails of an early bronco (must be 12" or less from center of rear output shaft to outside edge of transfer case. Forward drive shaft must be on driver side. Hopefully someone has done this and was able to keep the cost reasonable. I am also open to any other options you may have. Thank you in advance for any suggestions. Email me
