plastic fuel lines ?
stiffy
I would like to bring my fuel system back to original. Im not sure how ford joined the plastic to the sending unit and dual tank valve. I cant believe they would have just put the plastic hose into rubber hose and clamp it. If someone knows the right way it would be MUCH appreciated.
Our Sponsor, Jeff's Bronco Graveyard
has 12 feet of plastic nylon fuel line just like OEM.
5/16" diameter
$18.00
http://broncograveyard.com/bronco/i-10296-plastic-nylon-main-fuel-line-66-77.html'>http://broncograveyard.com/bronco/i-10296-plastic-nylon-main-fuel-line-66-77.html
Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
