Rear Axle ratio codes
Status
Not open for further replies.
Bronco Noob
Hey guys! I am not sure if this is a repost or not.. but I found this while doing some research, SO HELPFUL! So if it helps you, MISSION SUCCESS. Have a good one. :)>-
THE FIRST TWO DIGITS OF THE AXLE CODEIDENTIFY THE RATIO AND CAPACITY OF THEREAR AXLE.THE FOLLOWING CHART LISTS THESECODES, THE CORRESPONDING RATIO ANDCAPACITY AS WELL AS THEMANUFACTURER'S NAME AND MODELNUMBER.
MANUFACTURER
CODE YEAR RATIO CAPACITY NAME MODEL DESCRIPTION
A1 80/81 2.75 2.8M Ford Limited Slip
A1 83 2.75 2.8M Ford
A2 81 3.00 2.8M Ford Limited Slip
A2 85/ 4.10 2.77M, 2.79M Ford Locking
A3 88/ 3.45 2.77M, 2.79M Ford Locking
A4 81 3.25 2.8M Ford Limited Slip
A4 85/ 3.73 2.77M, 2.79M Ford Locking
A7 81 2.47 2.8M Ford Limited Slip
B1 83 3.00 5.3M Dana (Spicer) Limited Slip
B1 84/85 4.10 5.3M Dana (Spicer) Limited Slip
B1 89 4.10 2.77M, 2.95M Ford Locking
B3 83/86 3.54 5.3M Dana (Spicer) Limited Slip
B4 85/ 3.73 5.3M, 2.95M Dana (Spicer) 60/61 Locking
B5 80/82 3.33 5.3M Dana (Spicer) 60/61 Limited Slip
B5 85/ 4.10 8.5M Ford Limited Slip
B5 86/ 4.10 5.3M Ford Limited Slip
B6 83/84 3.55 4.05M Ford Limited Slip
B7 82 3.54 5.3M Dana (Spicer) 60/61 Limited Slip
B7 85/86 3.73 8.5M Ford Limited Slip
B7 86 3.73 5.3M Dana Limited Slip
B9 85/ 3.55 8.5M Ford Limited Slip
B9 86/ 3.55 5.3M Ford Limited Slip
C1 81/82 4.10 5.3M Dana (Spicer) 60/61 Limited Slip
C2 81/82 3.00 5.3M Dana (Spicer) 60/61 Limited Slip
C2 83/85 4.10 6.25M Dana (Spicer) Limited Slip F Series
C2 85/ 4.10 6.25M, 6.34M Dana (Spicer) Limited Slip Econoline
C2 83/84 4.10 6.34M Dana (Spicer) Limited Slip Econoline
C2 83 4.10 6.25M Dana (Spicer) Limited Slip
C3 80 3.31 5.3M Dana (Spicer) 60/61 Limited Slip
C3 83/84 3.54 6.25M Dana (Spicer) Limited Slip
C3 85/ 3.54 6.34M Dana (Spicer) Limited Slip Econoline
C4 83/84 3.73 6.34M Dana (Spicer) Limited Slip
C5 85/ 4.10 6.25M Ford Limited Slip Bronco, F Series
C6 82 3.73 6.34M Dana (Spicer) 60/61 Limited Slip
C7 80/82 3.54 5.3M Dana (Spicer) 60 Limited Slip
C7 82 4.10 6.34M Dana (Spicer) 60/61 Limited Slip
C9 85/ 3.55 6.25M Ford Limited Slip Bronco, F Series
D1 82 3.54 6.25M Dana (Spicer) 60/61 Limited Slip
D2 83/85 4.10 7.4M Dana (Spicer) Limited Slip
D2 83/84 3.45 2.5M Ford Limited Slip Bronco II
D3 80/82 4.10 6.25M Dana (Spicer) Limited Slip
D3 83/85 3.54 7.4M Dana (Spicer) Limited Slip
D4 83/ 3.73 2.5M, 2.64M Ford Limited Slip Bronco II
D5 85/ 4.10 7.4M Ford Limited Slip Bronco II, F Series
D6 82 3.73 7.4M Dana (Spicer) 60/61 Limited Slip
D7 80/82 4.10 7.4M Dana (Spicer) 70 Limited Slip __
D7 85/ 4.10 2.5M, 2.64M Ford Limited Slip
E2 80/ 4.10 7.4M, 7.8M Dana (Spicer) 70HD Limited Slip
E3 83/84 3.54 7.4M Dana (Spicer) Limited Slip
E4 83/85 3.73 7.4M Dana (Spicer) Limited Slip
F3 85 3.54 8.2M Dana Locking
F4 83/86 3.45 2.7M Ford Locking Ranger
F5 85/ 4.10 8.25M, 11M, 11.5M Ford Limited Slip
F5 85 3.45 2.7M Ford Limited Slip Ranger
F6 83/ 3.73 2.7M, 2.75M Ford Locking Ranger
F7 84/ 4.10 2.7M, 2.75M Ford Locking Ranger
F9 85/86 3.55 8.25M Ford
G2 85 4.10 6.3M Dana (Spicer)
G3 85 3.54 6.3M Dana (Spicer)
H2 80 3.50 3.75M Ford Limited Slip
H3 80/82 2.75 3.75M Ford Limited Slip
H3 85/86 4.11 3.75M Ford Locking
H4 80 3.25 3.75M Ford Limited Slip
H4 81/86 3.00 3.75M Ford Limited Slip
H5 81/82 3.25 3.75M Ford Limited Slip
H5 83 2.73 3.75M Ford Limited Slip
H5 87/ 4.10 3.8M Ford
H6 81/87 3.50 3.75M Ford Limited Slip
H7 80 3.00 3.75M Ford Limited Slip
H7 81/82 2.47 3.75M Ford Limited Slip
H8 83/86 3.08 3.75M Ford Limited Slip
H8 87/ 3.08 3.8M Ford Limited Slip Bronco, F Series
H9 83/ 3.55 3.75M Ford Limited Slip
H9 87/ 3.55 3.8M Ford
K6 84/86 3.73 3.2M Ford Locking
W5 89 4.10 8.25M Ambulance pkg. wide track rear axles
01 80/82 2.75 2.8M Ford
02 80/82 3.00 2.8M Ford
04 81/82 3.25 2.8M Ford
07 81/82 2.47 2.8M Ford
12 86/ 4.10 2.77M, 2.79M Ford Aerostar
12 87/ 2.73 3.75M, 3.8M Ford
13 80/82 2.75 3.75M Ford
13 85/86 4.11 3.75M Ford
13 86/ 3.45 2.77M, 2.79M Ford Non-locking Aerostar
14 80/87 3.00 3.75M Ford Non-locking
14 86/ 3.73 2.77M, 2.79M Ford Non-locking Aerostar
15 80/82 3.25 3.75M Ford
15 83 2.73 3.75M Ford
16 80/87 3.50 3.75M Ford Non-locking
17 81/86 2.47 3.75M Ford
17 88 2.73 38M Ford Non-locking
18 83/ 3.08 3.75M Ford Non-locking
18 86 3.00 38M Ford
18 87/ 3.08 3.8M Ford Locking
19 83/ 3.55 3.75M Ford Non-locking
19 87/ 3.55 3.8M Ford Locking
21 83 3.00 5.3M Dana (Spicer)
22 80 3.07 5.3M Dana (Spicer) 61
22 83 3.55 3.75M Dana (Spicer) Limited Slip
22 84/85 4.10 5.3M Dana (Spicer)
23 80/81 3.31 5.3M Dana (Spicer) 60/61
23 83/ 3.54 5.3M Dana (Spicer) 60/61 Non-locking
23 86/ 3.45 2.77M Ford Aerostar
24 83/ 3.73 5.3M Dana (Spicer) 60/61 Non-locking
24 86/ 3.73 2.77M, 2.95M Ford Aerostar
25 80/82 3.33 5.3M Dana (Spicer) 60/61 Non-locking
25 85/ 4.10 5.3M Ford Regular
26 83/87 3.55 3.75M Ford Non-locking
27 80/82 4.10 7.4M Dana (Spicer) 70 Non-locking
27 84 4.10 5.3M Dana (Spicer)
27 85/ 3.73 5.3M Ford
28 80/82 4.56 7.4M Dana (Spicer) 70
29 85/ 3.55 5.3M Ford Regular
31 81/82 4.10 5.3M Dana (Spicer) 60/61 Non-locking
31 83/86 3.07 6.34M Dana (Spicer) Non-locking Econoline
31 83/86 3.07 6.25M Dana (Spicer) F Series
32 81/82 3.00 5.3M Dana (Spicer) 60/61 Non-locking
32 83/ 4.10 6.34M Dana (Spicer) Non-locking Econoline
32 83/86 4.10 6.25M Dana (Spicer) F Series
32 83 3.08 2.5M Ford Bronco II
33 83/ 3.54 6.34M Dana (Spicer) Non-locking
33 83/85 3.54 6.25M Dana (Spicer) F Series
33 88/ 3.45 2.77M, 2.79M Dana Non-locking
34 83/84 3.73 6.25M Dana (Spicer) F Series
34 83/ 3.73 6.34M Dana (Spicer) Non-locking
34 85 3.73 6.25M Dana (Spicer) F Series
34 87/ 3.73 2.77M, 2.79M Ford Regular
35 85/ 4.10 6.25M Ford Regular
35 88/ 4.10 8.5M Regular FX250
36 80/82 3.73 7.4M Dana (Spicer) 70 Non-locking
37 80/82 3.54 5.3M Dana (Spicer) 60/61 Non-locking
38 80/82 3.73 5.3M Dana (Spicer) 60/61 Non-locking
38 85/86 3.08 6.25M Dana (Spicer)
38 86 3.08 6.25M Dana (Spicer)
39 85/ 3.55 6.25M Ford Regular
39 88/ 3.55 8.5M Ford Regular FX250
41 80/82 3.54 6.25M Dana (Spicer)
41 84 3.08 2.5M Ford
42 80/82 3.73 6.25M Dana (Spicer)
42 83/86 4.10 7.4M Dana (Spicer) F Series
42 83/85 3.45 2.5M Ford Bronco II
42 86/ 3.45 2.64M Ford Regular Bronco II
43 80/82 4.10 6.25M Dana (Spicer)
43 83/85 3.54 7.4M Dana (Spicer)
44 80/82 4.56 6.25M Dana (Spicer)
44 83/85 3.73 2.5M Ford Bronco II
44 86/ 3.73 2.64M Ford Regular Bronco II
45 85/ 4.10 7.4M Ford Regular
46 82 3.73 6.34M Dana (Spicer) Non-locking
47 82 4.10 6.34M Dana (Spicer) Non-locking
47 85 4.10 2.5M Ford Non-limited Slip
47 86/ 4.10 2.64M Ford Regular Bronco II
49 85/ 3.55 7.4M Ford Regular
51 80/83 3.73 7.4M Dana (Spicer) 70HD
52 80/ 4.10 7.4M, 7.8M Dana (Spicer) 70HD Non-locking
53 80/82 4.56 7.4M Dana (Spicer) 70HD
53 83/ 3.54 7.4M, 7.8M Dana (Spicer) Non-locking
53 83 4.56 7.4M Dana (Spicer)
55 86 3.55 3.2M Ford Non-limited Slip Ranger
62 81/82 4.10 8.1M Dana (Spicer) 70HD
62 83/86 4.10 8.2M Dana (Spicer)
63 85/86 3.54 8.2M Dana (Spicer)
65 83/86 4.56 8.2M Dana (Spicer)
65 85/ 4.10 8.25M Ford Regular
69 85/ 3.55 8.25M Ford Regular
72 83/86 3.08 2.2M Ford
72 85 4.10 6.3M Dana (Spicer)
72 88/ 4.63 11M Dana Non-locking
73 85 3.54 6.3M Dana (Spicer)
73 88/ 5.13 11M Dana Non-locking
74 83/84 3.45 2.2M Ford
81 85 2.73 2.7M Ford Non-limited Slip Ranger
82 84/86 3.08 2.7M Ford Regular Ranger
82 89 3.08 2.7M Ford Regular Ranger
84 83/ 3.45 2.7M Ford Regular Ranger
86 83/ 3.73 2.7M Ford Regular Ranger
87 84/ 4.10 2.7M Ford Regular Ranger
96 84/86 3.73 3.2M Ford Regular Ranger
SOURCE: purple55 @ Ford-trucks.com (http://www.ford-trucks.com/forums/297637-rear-axle-ratio-codes.html)
Status
danno
