Identification, 5.0 & 5.8
To determine which EFI V-8 engine you have, look closely at the EGR Tube;
The 5.0L EGR Tube runs from the lower intake manifold to bottom of EGR Valve
http://broncozone.com/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=11910
The 5.8L EGR Tube runs from the passenger exhaust manifold to bottom of EGR Valve
http://broncozone.com/uploads/monthly_04_2012/post-3816-0-34515500-1335352077_thumb.jpg
quick ID tip: The lower thermostat housing bolt on the 302 will be below the top of the water pump and you won't be able to put a socket on it. On the 351W you can remove the bolt with a socket.
The positive ID is to measure the lower intake; 302 is aprox ~ 8 inches wide. 351 is aporx ~ 11 inches wide.
The 5.0L uses squared ports and the 5.8L uses oval ports. If you get an intake from a junk yard it will have the matching fuel rail..." Read More
Source: by fordification.com & Ryan M (Fireguy50) via miesk5 at Ford Bronco Zone Forum
Filter Magnet; E4OD Kills Engine in Gear; "...works as a filter retainer; w/Ford PN and size; basically this is a magnet Ford uses to keep the filter in-place tightly into the pump; Ford pn F3RZ-7E290-AC..."
Source: by spxfiltran.com via web.archive
http://web.archive.org/web/20050213234632/http://www.spxfiltran.com/Bulletins/toledo/techbulletin.asp?num=037
Kills Engine in Drive or Reverse; may be caused by a faulty Vehicle Speed Sensor (VSS); also called RABS Sensor & Differential Speed Sensor (DSS) signal to the PCM. Observe the speedometer gauge or VSS signal on a scan tool. If the VSS display exceeds 90 MPH (may be higher on some models), the EEC (computer) is programmed to stop pulsing the fuel injection. If this occurs at low speed or while idling, suspect a bad Programmable Speedometer Odometer Module (PSOM).
VSS Test; Disconnect vehicle speed sensor connector. Measure resistance between the two pins on the vehicle speed sensor. Is reading between 800 and 1400 ohms? Yes - Vehicle speed sensor checks OK. No - REPLACE sensor.
Speed Input Signal Test at PSOM connector in 93-96 Bronco; "...NOTE: Only wiring harness end of connector is to be probed. * Connect Rotunda Digital Volt-Ohmmeter 014-00407 or equivalent to Pin 4 (speed in ) and Pin 5 (speed in -). * Does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts as vehicle speed increases from 0 to 48 km/h (0 to 30 mph)? OR: If available, a frequency counter may be connected to Pin 4 (Speed in ) and Pin 5 (Speed in -). Does the displayed frequency of the signal increase smoothly and continuously from 0 to approximately 667 Hz at approximately 48 km/h (30 mph)? OR: *
If neither a voltmeter nor frequency counter is available, vehicle speed control may be used as a good indicator. If it works normally, then the speedometer module is at least receiving a speed input signal and the wiring and sensor can be assumed to be good. Rear axle sensor should read 800-1400 Ohms across the pins, and more than 10 Ohms from the metal shell to either pin. To bypass the 4WABS module & feed the ABS signal directly to the PSOM, jumper 4WABS Control Module Bypass for PSOM Operation due to Bad 4WABS Control Module; "...To bypass the 4WABS module & feed the ABS signal directly to the PSOM, jumper 14 (CKT 530, LG/Y)to 21 (CKT 519 (LG/BK) & 39 (CKT 491 (O/LB)to 22 (CKT 523, R/PK)..." MIESK5 NOTE; see Steve's 4WABS Connectors Diagrams for 93-96 for the Module's Connector Pin-Outs..."; Miesk5 Note in 96 Ford shows 170-270 ohms across the pins
