Snapped Radius Arm
NaturalRampage
New Jersey, Bergen County
Heya guys. Recently my left radius arm snapped (Just as I was done for the day!) and I need some help with a few measurements before I can order new ones and replace em. My only problem is that the radius arms I believe are aftermarket but my truck has a lift on it (It's either 3 or 4 inch lift), but I need a definite measurement, so my first question being, what do I measure to find the number of inches the truck is lifted? I have some pictures (If I can upload them correctly) to help you guys help me out with this little kink. I'd appreciate any feedback! Thanks guys.
Krafty
Ontario Canada
the radius arm likley came in the kit the previous owner bought for the lift. judging by those pictures there is a camber adjustment nut also installed which means there probably wont be any axle drop brackets. my best guess is to try to track down the manufacturer of the kit (via the previous owner)and just order the replacement.
As KRAFTY Advised;
Look at this first;
by BRONCOSnBEER (Eddie Bauer) at http://www.supermotors.net/registry/17946/61174
and this Tuff Country 2.5" RA looks same as above abd Your's
by Trucky
Trucky wrote; "...Here is one of the new arms mounted on the Truck. Notice the cam adjusting bolt on the pivot point of the new radius arm. The Tuff Country kit does away with the ford style radius arm bushing, and gives you a grease-able bolt in a poly bushing, much better than having to change those bushings all the time, also giving the alignment shop and easy adjusting point..."
more pics of the lift @ http://www.supermotors.net/registry/3749/14102
and to help narrow it down & compare to other Brands; Our Sponsor, Jeff's Bronco Graveyard has a bunch of Lift Kits by various mfgrs. w/some pics
http://broncograveyard.com/bronco/b-509-lift-kits.html
and
By Doba
Rough Country pic
http://images24.fotki.com/v863/photos/1/109911/4088790/DSCN2507-vi.jpg
looks diff
Black Diamond
http://www.superlift.com/Resources/_Goliath/Images/Preview/SEIK385.jpg
looks diff
**** Cepek
http://www.supermotors.net/clubs/superford/registry/media/468485'>http://www.supermotors.net/clubs/superford/registry/media/468485
looks diff
Cage Offroad
http://www.supermotors.net/registry/media/161653 looks diff
Deaver Superflex
http://www.supermotors.net/registry/media/198259
looks diff
James Duff
looks diff
ProComp 4 inch Stage II Lift Kit
http://www.procompusa.com/prodDetail.aspx?partNo=EXPK4070B&catID=1&subCat=38&ptID=3533&plID=1808
looks closeStage II 6 inch
http://www.supermotors.net/registry/media/446896
looks diff
Rancho®
looks diff
Rough Country® 4 inch Bracket
http://www.supermotors.net/clubs/superford/registry/media/52654
looks diff
Skyjacker® 6 inch
looks diff
Superlift® 6 inch
http://www.supermotors.net/clubs/superford/registry/media/54079]Tim wrote; "...New superlift radius arms are 18" longer than stock and are the new tubular design..."
looks diff
scrubtopdoc
