Hello - I have a 1994 bronco that I just put new radius arms on. Everything has been installed and tightened down appropriately. I have thoroughly inspected everything, re-tightened bolts, replaced the 'rear' axle pivot bushing, replaced the brakes, put two new shocks on (quad shocks), replaced tie rod ends, got it aligned, ..etc. For whatever reason, I now hear a very deep clunk when I am in reverse and turn the wheel to the right when backing up. I can't understand where this could be coming from where there is so little room for movement in the front end :angry: . Has anyone else experienced this before? Thanks in advance.
