mistaken36
- Joined
- Dec 9, 2010
- Messages
- 3
- Reaction score
- 0
jus installed an 8 blade , 16" 10 amp fan. now runs hotter than with the manual fan off the pump. it pulls air ,an the shroud is on.
What is the CFM rating of the fan? What is the climate you are operating in like? What size radiator? Were you having cooling problems prior to installing the fan?jus installed an 8 blade , 16" 10 amp fan. now runs hotter than with the manual fan off the pump. it pulls air ,an the shroud is on.
