Jump to content
6" suspension and 2" body lift or 8" suspension lift
2 replies to this topic
#1 brad6920
brad6920
    It's Only Money, Right?
  • Members
  • PipPipPip
  • 40 posts
  • Gender:Male
  • Favorite Bronco Year?:1994
Posted 15 May 2012 - 01:25 AM
Okay, I have read all the topics I could, but I still need some help. I have a '94 Bronco and I want to run 37" tires but I don't think they will fit with just a 6" lift...right? If not, can I put 2" spacers under the 6" lift coil springs or is it better to run a 2" body lift and the 6" suspension lift? Or maybe there is an 8" suspension lift that I have never heard of???
I don't do any serious offroading, mainly just snow and gravel logging roads, so will the stock suspension handle 37" tires or is this asking to much?
Any help is greatly appreciated.
#2 Rons beast
Rons beast
    Supreme Commander
  • Moderators
  • PipPipPipPipPipPipPipPip
  • 1530 posts
  • Gender:Male
  • Interests:sleeping, eating, building something, repeat.
  • Favorite Bronco Year?:1996
Posted 15 May 2012 - 04:43 AM
Do NOT put spacers under 6" lift springs....too unstable.
here is a link to a great thread. It has info on what gears you would need when going to bigger tires. http://broncozone.co...indpost&p=64103
If you are not running off road or doing rock climbing, why do you need the truck so high? As they get higher they are more unstable and harder to drive, because of raising the center of gravity.
( it is fun watching short people trying to get in)
Good Luck
Edited by Rons beast, 15 May 2012 - 04:54 AM.
04 Mercedes ML500
00 Linc LS "The Ride"
92 Mercedes 500SL "The Baby"
08 Mercedes SLK "The Wife's"
82 Chevy S10 Custom "The Project"
always changing (Given to my son)
96 Eddie Bauer (The Beast ) Sold
#3 Krafty
Krafty
    Supreme Commander
  • Members
  • 1049 posts
  • Gender:Male
  • Favorite Bronco Year?:1981
Posted 16 May 2012 - 02:06 AM
like ron said another issue I don't think you realized is that you will need to change your gear ratio to run 37's . probably to a 4.56 or so which means you may also need to replace the gaskets, crush sleeves and spacers in your axles to set your ring gear and pinion spacing.
81 Bronco 300 4spd, 4" skyjacker coils in front, 3" add a leaf by trailmaster in rear, and 2" blocks. 33x12.5x15, Sold my baby. ( I bought it when I was 13, hit the first mud hole at 14 ,did the first lift when I was 16)
89 F-150 302 efi 4x4 swapped the motor but had a bunch of problems sold for 500
79 Ford Thunderbird 429 swap summer car, Traded For Plymouth
93 F150 4.9 4x4 reg cab long box ,31x10.5x15 and custom bush bar, sold to young guy as a winterbeater
73 Plymouth Fury II 2dr Hardtop 318 auto
87 Z28 Camaro 350 with Nitrous
01 Dakota 3.9 5spd 4x4 Daily
83 Yamaha xj750 Seca fair weather toy.
07 Ford Escape (wife's Daily)
Reply to this topic
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
