Help!!! eletrical issues
bronco7696
:blink:my 1996 ford bronco was working perfect until one of two things which were done at same time, 1st. i was installing a used cluster bezel that already had the rear window swith & 4x4 selector on it, once plugged in, i didnt notice any issues except that switch didnt work, while in the process of doing i also had a check engine light that had been on since i purchased it and finall broke out the scanner to check the codes, once checked i cleared to see how long till they popped back up but in doing. but right before we did the scanner i could not unlock my passenger door with remote or switch. when i would hit the lock button it would work, but when you would hit unlock, it would cause all lights to flash and not unlock the doors, also noticed the door chime quit, no dome lights coming on. also when i cranked the truck up the odometer was not showing my miles and when i tried to drive home it would not shift gears. please help, i have searched all topics and can not find a similar problem... :wacko: :angry: <_< [-o<
Elmo
Forsyth Georgia
Sounds like either something didnt get plugged up completely or the switches arent right for the 1996, like the connectors are the same but the inside configuration of the switch is different. First thing i would do is undo the cluster bezel. Put everything back as it was and see if the problems go away.
yo bronco7696,
WELCOME!
Here is the 96 PDL/RKE Wiring Diagram
96 Harness Removed; ck the PW/DL Connectors
Wiring Harness & Component Location Diagram, Ford Part Numbers, Depictions, etc. from Ford Workshop Manual96InstrumentPanelHarness.gif
Item Part Number Description
1 To Headlamp Switch
2 To Fuse Box
3 14A282 Retainer Assembly
4 N606678-S39 *****
5 Connector (Part of 12A581)
6 Connector (Part of 14A504)
7 13A506 Locator, Position in Hole Provided
8 To Park Signal Lamp Switch
9 To Multi-Function Switch (turn/wiper/ws washer/flash to pas/hi beams switch)
10 To Stoplight Switch
11 Clip (Part of 14401)
12 E4OD Pigtail (Part of 14401)
13 To Ignition Switch and Steering Column Wiring
14 To 14405
15 To Starter Switch Clutch Interlock
16 Take-Out to Shift on the Fly Switch (MIESK5 Note, this is the " 4x4 selector") and Electric Defrost Switch (Part of 14401)
17 To Warning Buzzer Chime
18 Remote Keyless Entry Programming Connector
19 15K602 Remote Keyless Entry Module
20 Air Bag Module
21 14A163 Retainer Assembly
22 To Trailer Brake Controller
23 14A099 Shield
24 Vacuum Hose Clip (Part of Vacuum Harness)
25 Ashtray Wiring (Part of 13726)
26 15A044 Cigar Lighter
27 PSOM Test Circuit (Part of 14401)
28 To Bowden Cable
29 18813 Radio Antenna
30 Brake Anti-Lock Module Test Circuit (Part of 14401)
31 To 14630
32 To 14B095
33 To 18A586
34 To Right Courtesy Lamp Switch
35 To Inertia Switch
36 14463 To Ground
37 To Clearance Lamp F-Series Only for Continuation
38 Wiper Control Module
39 2C018 Rear Brake Anti-Lock Module (F-150, F-250, F-350 Only)
40 To Glove Box Lamp
41 To Heater Mode Switch
42 To A/C Illumination
43 To A/C Blower Switch
44 To Power Point
45 To Radio
46 18B849 Premium Sound Amplifier
47 14B166 Shift on the Fly Switch
48 To 14A262 Electric Defrost (Bronco Only)
49 14401 Wiring Assembly
50 To Cluster (Plug A)
51 To PSOM
52 To Cluster (Plug B)
53 14B155 Cap
54 04320 Instrument Panel
55 9A050 Dual Fuel Tank Switch (F-Series Only)
56 14529 Rear Window Control Switch (Bronco Only)
57 Demister Hose
58 To Glove Box Lamp
The passenger door harness disconnects inside kick panel; the driver door harness is continuous from the door lock motor all the way over to those passenger connectors
Lana Kane
