Manual transmission identification?
10sun
East Franklinton, OH
I haven't had a chance to get climbing under my 1983 Bronco that much other than to adjust the clutch (I was hoping that would help out with the difficult start ups & impossible downshifting to 1st, not the case... it feels like it is unsynchronized).
It is dark out and the ground is muddy, so I don't feel like wiggling under there much tonight; so I am going to try to crowdsource the answer.
The Base Info that I know: 1983 Fullsize Bronco // i6 300 // 4 speed manual // 4L 4H 2H transfer case
My shift pattern is:
R13
_24
From what I have been reading the Borg Warner T18 & NP 435 are both:
13
24R
Any ideas? I'm just trying to figure out what the **** it is.
Krafty
Ontario Canada
sounds like a 4sp toploader or T-170 from a mustang or ranchero, I had a t-18 in my 81 bronco and yeah the shift pattern was
1 3
2 4 R
our 69 mustang on the other hand is a 4 spd top loader with
R 1 3
2 4
ps cant get the damn number spacing right on the bottom one but you get the idea
Krafty
Ontario Canada
I did however just read that different years/ models with the t-18 used both shift patterns. step one would be to have a good look at it and try to id it from a tag, serial number, or overal size and dimensions.
10sun
I'll crawl under there tomorrow to take a closer look. It definitely feels like 1st & reverse aren't synchronized which would eliminate the toploader, but it could just be the fact the clutch is shit.
I appreciate your insight.
Krafty
Ontario Canada
my t-18 also didnt have syncros on 1st or reverse, but my 1st was also so slow I could take off in 2nd, and usually did. 1st was more for taking off with a load from a stop where you don't need a syncro, and no reverse syncro was a sort of saftey mechanism so you dint hit reverse while trying to hit another gear.
Model: M5OD-R2
Type: Five speed Mazda Overdrive
Years: 88-96 Bronco, F150s
97-03 F150s
05 F150 (v6)
Engines: 300, 302, 4.2L, 4.6L
Fluid: Mercon
shift pattern is:
1.3.(D)
2.4.R
Ratios:
1st 3.90:1
2nd 2.25:1
3rd 1.46:1
4th 1.00:1
5th 0.80:1
Construction features: External Ribs in square patterns
Trans code: M
Model: SROD
Type: Four speed overdrive w/ push down reverse
Years: 80-83(4?)
Engines: 300, 302
Fluid: ?
shift pattern is:
P..R..1..3
U
S.....2..OD
H
Ratios:
1st 3.25:1
2nd 1.92:1
3rd 1.00:1
4th 0.78:1
Reverse 3.25:1
Construction features: Aluminum, shifter near back
Trans code: B
Model: NP-435
Type: Four speed non overdrive
Years: 80-87?
Engines: 300, 302, Your mostly gonna find it behind a 300.
shift pattern is:
1.2
3.4.R
Construction features: Cast Iron w/aluminum top plate, shifter in top, PTO Pass side
Fluid: 140w
Ratios:
1st 6.69:1
2nd 3.34:1
3rd 1.79:1
4th 1.00:1
Reverse 3.25:1
Trans code: A
Model: T18
Type: Four speed, non overdrive, non syncro first gear
Years: ?
Engines: 300, 302, 351, 460
Fluid: ?
shift pattern is:
1.3
2.4.R
Construction features: Cast iron throughout
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code: F or P
Model: T19
Type: Four speed, non overdrive, syncro first gear
Years: ?
Engines:460?, 6.9L, 7.3L
Fluid: ?
shift pattern is:
1.3
2.4.R
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code F or P
Model: ZF5
Type: Five speed heavyduty overdrive
Years: 87-99 F2/3/450/superduty
Engines: 300, 351, 460, 7.3
Fluid: Mercon
shift pattern is:
1.3.(D)
2.4.R
Ratios:
S5-42 (Diesel)
1st: 4.14
2nd: 2.37
3rd: 1.42
4th: 1.00
5th: 0.77
Reverse: 3.79
RTS 4-spd w/OD (Transmission code is B)
T170FT-RTS Top loaded 4 speed with 4th being overdrive. Aluminum case and shift tower. 1984-87 Trucks: Aluminum, top loaded case with tower shift. All units have Overdrive. Mainshaft Reverse is located on the outside of the 1st/2nd slider and all synchro rings have 36 teeth. The 3rd gear on the cluster gear is larger than the 4th gear (the front gear). Casting number 260XXXX
The RTS shifter housing comes straight up off of the trans and not the tailshaft housing like the other tremec. It also does not have a side cover on the RTS.
Aluminum casing and the code "RTS" stamped on the tag
The shift pattern is:
13
24R
The RTS has an aluminium case and no drain plug (unless added)
more Info LINKS in my site @ http://www.broncolinks.com/index.php?index=16
Brwbronco
I had the same problem identifying my tranny. My bronco is an 82 with the inline 6 but I have the same shift pattern. I believe what it is Model SROD
Years: 80-83(4?)
Engines: 300, 302
Fluid: ? (I've been told it uses
shift pattern is:
R..1..3
...2..OD(4)
Ratios:
1st 3.25:1
2nd 1.92:1
3rd 1.00:1
4th 0.78:1
Reverse 3.25:1
Trans code: B
denny.dikes
