Need help to remove quarter window
Roadking
I need a guide to remove the quarter window pics would be nice to show how to remove it. its a 93 bronco xlt
If you are talking about the wing vent window, it is very easy to remove.
1. On the front edge of the door there are two screws that must come out. They may be covered by the door weather stripping.
2. Remove the door panel.
3. lower the large glass.
4. remove the, (I believe it is a 10 mm bolt), attaching the glass track.
5, You may have to pull the top glass weather strip out away from the track.
6. Pull back on the top of the wing window frame. If it doesn't pull back, there may be a ***** under the mirror, not all have it. In that case you have to remove the mirror to get at it.
It is accessed through a hole that is between the mirror bolt holes.
7. Once the frame is tilted back you need to rotate it about 90 degrees to get the mounting tabs through the window slot in the door.
Sorry, but I don't have any pictures for you. Hope that helps.
This diagram is by Ford in Workshop Manual
Item Part Number Description
1 21402 Front Door Vent Window
2 21448 Weatherstrip, Front Door Vent Window
3 21596 Front Door Glass Top Run
4 21410 Front Door Window Glass
5 21458 Front Door Glass Channel and Retainer
6 351909-S ****** Front Door Vent Window Frame-to-Front Door Vent Window Division Bar
7 21452 Front Door Belt Line Outside Weatherstrip
8 21456 Front Door Belt Line Inside Weatherstrip
9 22A00 Front Door Glass Run Latch Side Retainer
10 23240 Window Regulator Arm Roller
11 23200 Front Door Window Regulator
12 23342 Window Regulator Handle
13 23370 Window Regulator Handle Plate
14 23227 Window Regulator Handle Seal
15 22926 Pivot Spring, Front Door Vent Window
16 22963 Pivot Washer, Front Door Vent Window
17 22916 Front Door Vent Window Handle
18 21608 Frame, Front Door Vent Window
19 21408 Weatherstrip Retainer, Front Door Vent Window
20 22296 Division Bar, Front Door Vent Window
21 23208 Front Door Power Window Regulator Minus Motor
22 385189-S Rivet
23 23394 Window Regulator Electric Drive
24 234A24 Window Regulator Drive Gear Kit
digs
