I have moved this actual question from my intro from last night. Thanks Bully Bob for your response. I'm a novice at best at this forum stuff.I have a question about the gas tank switch valve. The guy i bought her from said it was bad, and would leak fuel in the floor board if i put more than a couple of gallons of fuel in her. He also gave me another switch valve to use. I just took it apart, and found that it also is bad. ( See attached pic.)
My question, is why does'nt someone make a replacement diaphram to go into the brass valve? It seems pretty simple to me?
All i have been able to find online, is after market valves, that look nothing like the original.
Any Thoughts?
Bully Bob, I will wait for you to post your answer here before i continue with more observations, and questions. Thanks again.
Any Thoughts?
