Test & Installation Tips in a 90;
"...My oil pressure gauge was reading on the "N" of the NORMAL range. After doing some research it seemed like it could be the oil pressure switch, also known as a sensor or sending unit.
Disconnect the wire from the switch, ground it to the truck and turn the key on. If your gauge quickly moves to the left, the problem is most likely the switch.
The switch on my 5.8 is located near the oil filter. It is in a difficult spot to work on so I advise that you go to NAPA and get an Oil Pressure Switch socket to do the job. The cost is about $7-$8, this will save you time and will help you reinstall the new switch. Wrap some teflon tape around the threads and install. Make sure that it is in tight, I don't know about torque specs, I just put mine in quite snug. Hook the wire back on and start your engine. For me it was the cure. My oil pressure now reads over near the "M" on NORMAL..." miesk5 Note; The stock gauge & Sender will drop off after pressure reaches a certain level. You might actually have 5 psi, but the gauge will read 0 PSI..."
Sender Location pic in a 90 5.8
Source: by SeattleFSB (Seattle FSB) at SuperMotors.net
btw,
Oil Pressure Mod to Actual PSI "...short R in PCB..." info & NAPA Sender, etc. Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
The oil pressure gauge is a magnetic gauge movement consisting of three primary coils, one of which is wound at a 90-degree angle to the other two. The oil pressure system uses a switch and a fixed resistor; the resistor is attached to the engine wiring harness. A primary magnet, to which a shaft and pointer are attached, rotates to align this primary field, resulting in pointer position. The bobbin/coil assembly is pressed into a metal housing which has two holes for dial mounting. There are no adjustment calibrations or maintenance required for this gauge.
Sender Failure; "Corrosion or faulty electrical connections; If the oil pressure gauge is pegged low after the engine is running, or is pegged high after the engine is running, or if there is intermittent illumination of an oil pressure indicator light, the sender could be faulty. Related Components to Check; All appropriate electrical connections to and from the sender The oil pressure gauge or indicator light; Appropriate fuses (see Shop or Owner’s Manual for fuse layout)..." Source: by MOTORCRAFT®
