yo Broncoguy09,
It would have been better to begin a new post your issue.
try a Self Test for Codes by my pal, BroncoJoe19 @
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
do the KOEO = Key On Engine Off portion first & Remember to have engine @ Normal Operating Temperature before doing the KEY ON ENGINE RUNNING (KOER) portion
post any Code(s) found here; by,
KOEO
KOER
DTC 565 "...The canister purge solenoid dangles in its vacuum line between the R side of the engine and the canister on the R frame rail, so its wiring could have hit the exhaust manifold..." by Steve83
DTC 565 Pin-Point Testing & Possible Causes
From Ford;
Possible causes:
Open harness (VPWR or CANP).
Damaged CANP solenoid.
Shorted (power to ground) harness.
Damaged Powertrain Control Module (PCM) (LESS LIKELY!!!)
Key on, engine off.
Disconnect appropriate CANP solenoid.
Measure voltage between VPWR at the CANP solenoid vehicle harness connector and battery ground.
Is the voltage greater than 10.5 volts?
Yes - GO to KD7
No - SERVICE open VPWR circuit. RECONNECT CANP solenoid. RERUN Quick Test
KD7 CHECK CANP RESISTANCE
Key off.
Measure CANP solenoid resistance.
Is resistance between 30 and 90 ohms?
Yes - GO to KD8
No - REPLACE CANP solenoid. RERUN Quick Test.
KD8 CHECK CONTINUITY OF CANP CIRCUIT
Key off.
Appropriate CANP solenoid disconnected. (some Fords have two)
Disconnect Powertrain Control Module (PCM). Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
Install breakout box (see Pin Outs below to check w/o this box), leave PCM disconnected.
You can just use a digital multimeter in place of the breakout box
Measure resistance between Test Pin 11, 15, 31 or 54 (refer to pinpoint test schematic ) at the breakout box and CANP circuit at the CANP solenoid vehicle harness connector.
Is resistance less than 5.0 ohms?
Yes - GO to KD9
No - SERVICE open circuit. REMOVE breakout box. RECONNECT all components. RERUN Quick Test
KD9 CHECK CANP CIRCUIT FOR SHORT TO GROUND
Key off.
Breakout box installed, PCM disconnected.
Disconnect Scan Tool from Data Link Connector (if applicable).
Measure resistance between Test Pin 11, 15, 31 or 54 (refer to pinpoint test schematic ) and Test Pins 40, 46 and 60 at the breakout box.
Is each resistance greater than 10,000 ohms?
Yes - GO to KD10
No - SERVICE short to ground. REMOVE breakout box. RECONNECT all components. RERUN Quick Test.
KD10 CHECK CANP CIRCUIT FOR SHORT TO POWER
Scan Tool disconnected from Data Link connector.
Measure resistance between Test Pin 11, 15, 31 or 54 (refer to pinpoint test schematic ) and Test Pins 37 and 57 at the breakout box.
Yes - REPLACE PCM. REMOVE breakout box and Scan Tool. RECONNECT all components. RERUN Quick Test.
No - SERVICE short to power. REMOVE breakout box and Scan Tool. RECONNECT all components. RERUN Quick Test.
Overview, Failure Symptoms & Depiction, general; "...Vent fuel vapors from the carburetor bowl or fuel tank to the charcoal canister, and control the purging of these and other vapors from the fuel tank into the intake manifold when certain engine speed and temperature conditions are attained. Above idle, the mixture becomes very rich. Stumble on acceleration, poor fuel mileage, flooded charcoal canister and catalytic converter overheat can occur. Check for ruptured diaphragms inside the valve and misrouted or damaged hoses..."
Source: by tomco-inc.com
Again, if you don't have or can't find a break-out box. (E bay has em for $$$.00) you can also check the wires to the PCM directly
here are the EEC Connector Pin Outs, Bronco & Ford Truck & Van: 4.9, 460, 5.0, 5.8; miesk5 Note, see his Connector Pin Diagram Link below)
http://fordfuelinjection.com/images/eec04.gif
Source: by Ryan M (Fireguy50) at fordfuelinjection.com
pic
Wiring Diagram in 92-95 Bronco & F Series
http://www.supermotors.net/getfile/831135/thumbnail/wiring9295.jpg
Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
Location pic in a 93 5.8
Source: by Bbronco311 at SuperMotors.net
SEE MY SITE @
http://www.broncolinks.com/index.php?index=1015 FOR MORE Canister Purge Solenoid Valve (CanP/CPRV)Info LINKS
(O) =Key On Engine Off test
® =Key On Engine Running test
(M) =Memory code
114 (O,R) IAT sensor out of range
Possible causes:
- Low coolant level (ECT).
Ambient temperature below 10�C (50�F)
- Faulty harness connector.
- Faulty sensor.
- Run engine for two minutes at 2000 rpm.
For No Starts:
- Check Resistance of Temperature Sensor - Engine Off
For vehicle stalls:
- Check that upper radiator hose is hot and pressurized.
- Rerun quick test.
542 (O,M) Fuel pump open, bad ground or always on
Check
inertia fuel shutoff switch; behind passenger side kick panel
No Start:
Inertia Fuel Shutoff (IFS) switch not reset or electrically open.
Open circuit between the fuel pump and FPM circuit connection to the power-to-pump circuit.
Poor fuel pump ground.
Fuel pump electrically open.
Engine Starts:
Fuel pump secondary circuit short to power.
Fuel pump relay contacts always closed.
Open in FPM circuit between PCM and connection to the power-to-pump circuit.
Left/front HO2S short to power (dual HO2S applications).
Damaged Powertrain Control Module (PCM).
On idling engine; Check for vacuum leaks using a mechanic's stethoscope with the probe removed, or a short garden hose section. Don't spray flammables on a running engine. Also check: vacuum hoses; intake manifold gasket & throttle body; PCV line; vacuum reservoirs: EGR Sys Vacuum Tank & 2ndry air (coffee can); AC, heater, defroster, vent control ckt & vacuum tank (plastic ball type), under dash & lines to heat/blend/etc. doors; power brake booster; cruise control ckt, etc & back to Vac Line T on intake manifold.
The vacuum gauge should show 18-22 in-Hg @ idle, and maintain a steady needle. Rev it up to ~2500 rpm, hold it steady, and you should see the needle drop, then slowly increase to a level close to the idle reading (though slightly lower is normal)..."
Normal Engine Vacuum at Idle; 15-22 in-Hg (-51 to -74 kPa ) in 96 Bronco-F-Series from 1996 All F-150, F-250, F-350, F-Super Duty and Bronco Vehicles Equipped with 4.9L, 5.0L, 5.8L or 7.5L Gasoline Engines, & 7.3L Diesel Engines Workshop Manual
Source: by Ford
Gauge Diagnosis - BEST!; Normal engine; Steady gauge 18"-20" at all speeds..." READ MUCH MORE
Source: by Craig U at
http://www.classictruckshop.com/clubs/earlyburbs/projects/vac/uum.htm
The brake booster vac line is where most insert a T fitting for a vac gauge hook-up; you can leave it in permanently and run the new hose in thru the clutch blank plate and mount the gauge on dash/A Pillar, etc. for an "everyday MPG driving tool" and troubleshooter
Vacuum Gauge Tester Instructions
http://www.fordf150.net/howto/diagnoseengine.php
this is by William T; "...I have a vacuum gauge mounted right in the dash of my truck. I use it to also help determine the load my engine is under while driving, and to estimate fuel economy.
Here is the gauge mounted:..."
http://www.fordf150.net/images/mytruck/vacgauge.jpg
SEE MY SITE @
http://www.broncolinks.com/index.php?index=907 for More Vacuum Line Routing Diagrams, Acronyms & Color Codes LINKs;
such as:
"...The vacuum hoses used in the passenger compartment control circuit are constructed from PVC plastic material. The vacuum hoses used in the engine compartment are constructed of Hytrel. Because of the materials used, the vacuum hoses should never be pinched off during diagnosis to locate a leak. Use Rotunda Vacuum Tester 014-R1054 or equivalent to locate vacuum leaks. A wood golf tee can be used as a plug when it is necessary to plug one end of a vacuum hose for leak test purposes..." from F-150, F-250, F-350, F-Super Duty and Bronco, F-Super Duty Motorhome Chassis Workshop Manual
Source: by Ford
"...Use "Hard (Heavy Duty)" vacuum line for booster. Regular rubber hose such as used for WS washer fluid line will likely collapse after about say, 20 years. Inspect for any sign of kinking or collapse. Check vacuum draw available with a gauge connected between engine and booster. At idle, healthy engines draw somewhere between 17 and 22 in Hg. Check vacuum by depressing brake pedal firmly until it stops. The gauge should read a drop to approximately 10 in. Hg and then quickly recover to a normal reading. If vacuum takes too long to recover, there is a restriction in the volume, i.e.: fitting clogged or vacuum hose collapsed. Repair as necessary. While a defective booster will cause a hard pedal, a spongy or low pedal requires a hydraulic system check..."
Vac. Tree Location pic in a 94 5.8
Source: by joelb23 at SuperMotors.net
Vacuum Hose, Mini-Tube Service in Climate Control System in a 96; "...Measure the length of the damaged area of the mini-tube vacuum hose. Cut a piece of standard 3mm (1/8-inch) ID vacuum hose approximately 25mm (1 inch) longer than the damaged area of the mini-tube vacuum hose. Cut the mini-tube vacuum hose on each side of the damaged area and remove damaged portion of the mini-tube vacuum hose. Dip the mini-tube hose ends in Tetra Hydro Furan (THF) or Methyl Ethyl Ketone (MEK). Either of these solvents will act as a sealer for the repair of the mini-tube vacuum hose. Insert the ends of the mini-tube vacuum hose approximately 9mm (3/8 inch) into the ends of the standard 3 mm (1/8-inch) ID replacement vacuum hose. Shake the service joint after assembly to make sure solvent is dispersed and vacuum line is not blocked internally. Test system for a vacuum leak in area serviced..." from 1996 F-150, F-250, F-350, F-Super Duty and Bronco, F-Super Duty Motorhome Chassis Workshop Manual
Vehicle Emission Control Information (VECI) Decal; Contains Vacuum Diagram & Calibration Parts List for 88 & UP. On-Line for Free at Ford. Click "Quick Guides" in left panel; Scroll to & CLICK VECI Labels "Provides Vehicle Emission Control Information (VECI) and a related calibration parts list." Enter applicable info (need to know your Calibration number from your B-pillar sticker). Vacuum Diagram is the same as the one on the core support or hood or air filter cover. Suggest Right Clicking this Hot Link & Open in New Window Source: by Ford motorcraftservice.com
