69 bronco with 96 parts
spencedog
im tring to put a 302 and an e40d with the bw 1356 in my early bronco...but the t case seems way to big to fit in and its hitting the frame. can i clock the t case or will that mess up my ground clearance?. am i better off with a c4 and dana 20?
69bronc347
southern michigan
i would suggest an aod which is still an overdrive 4spd, just not electronic, and they make adapters for the dana 20
69bronc347
southern michigan
yeah but if you think about it with that tranny/transfer case combo its longer than stock so you'll need custom length drive shafts. have you priced those? they are pretty spendy as well.. you could always go manual. what was wrong with the trans that was in it?
S
spencedog
we when i got is there was a rusted bolk of iorn in the engine hole and thats all that was under the bronco and some axles
msgsnprtom
