the factory amp is against the fire wall above and slightly to the right of the gas pedal
Location in a 96; "...I just went through intsalling a stereo in my 96 Bronco, the amp is under the dashboard, to the right of the steering column. It is the small rectangular box closest to the firewall. I thought it was in the back too, since the wiring harness that Crutchfield gave me was long enough to reach back. Highly reccommend bypassing the factory amp with the plug-in harness..."
Source: by Burns
Location in a 96; from 1996 Bronco-F-Series Workshop Manual; "...amplifier is behind the radio, mounted to a bracket on the instrument panel (04320). Disconnect radio amplifier wire harness. Remove two radio amplifier retaining screws. Slide amplifier slightly away from instrument panel bracket (to disengage the upper tab to instrument panel bracket) and then down to remove..."
Source: by Ford
Wiring Diagram in 87-96; Electronic Stereo Radio; from 1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual
Source: by Ford via miesk5
Radio Connector C2, AM, AM/FM, AM/FM Cassette
Pin Number Circuit Circuit Function
1 855 (LB) RR AMP Input Return
2 278 (P/W) Rear Speaker (RH)
3 858 (BR) RF Input Return
4 279 (W/R) Right Front Speaker
5 859 (Y) LR AMP Input Return
6 277 (LB/BK) Rear Speaker (LH)
7 857 (W/O) LF AMP Input Return
8 280 (LG) Left Front Speaker
1 694 (BK/LG) Audio Ground
2 — Not Used
3 694 (BK/LG) Audio Ground
4 484 (O/BK) Liquid Crystal Display
5 19 (LB/R) Instrument Panel Lamp Feed
6 137 (Y/BK) Ignition (Hot in ACCY or RUN)
7 57 (BK) Ground
8 797 (LG/P) Battery Feed to Stereo
Radio Connector C1, All Non-Premium Sound Radios
