Trans Cooler Lines!
Bang61
Hey I have a 1995 5.8L w auto trans and while changing the radiator I accidentally ruptured one of the transmission cooler lines....I have been asking around and it seems that it is very difficult to find any new replacement cooler lines. I want to replace both lines since they are very rusted and I am already replacing both the radiator and transmission. Would anyone have any referrals they could make to me regarding these lines? Any help will be much appreciated....
You could use the connector ends with about 2-4 inches of the old line still in it and use fuel rated rubber tubing to make the connections, which I had for a while. OR, get some pre-manufactured lengths of steel line and bend your own, which is what I have now. Pictures of both attached, just keep the elongated adapter that is at the radiator.
Bang61
Thanks A Lot! I guess the pre manufactured steel lines is the route I will take.
