95 Bronco will not fire
Gnash
she turns over very strong... I have fuel and air btu no spark. I have replaced ignition coil, ignition module and the magnetic pick up in the distributor along with the whole distributor. 351W if there is another idea out there that may help. I would greatly appreciate it.
thank you
Here is some information that may help you with troubleshooting the problem. It comes from the EVTM (Electrical and Vacuum Troubleshooting Manual. It is probably the single most valuable Service Manuals you can own and is often found on eBay. I just did a search for one and it is available at a steal, they usually go for around $25.00 http://cgi.ebay.com/ebaymotors/1995-Ford-Bronco-Truck-EVTM-Shop-Manual-_W0QQcmdZViewItemQQhashZitem3f04ddeb4fQQitemZ270664592207QQptZMotorsQ5fManualsQ5fLiterature
In addition to that if you can find a factory set of Maintenance manuals go for it. They usually run betweden 100.00 and 200.00 for a complete set. http://shop.ebay.com/i.html?_nkw=1995+ford+Bronco+service&_sacat=0&_dmpt=Motors_Manuals_Literature&_odkw=ford+Bronco+service&_osacat=0&_trksid=p3286.c0.m270.l1313 I'd buy that first set, it has all the manuals for the 95.
BroncoJoe19
I'd check to see if i had power to the bat side of the coil, both with the key ON/Run, and with the help of a helper, while the engine is cranking.
I'd check my fuses, and listen for the fuel pump to prime (assuring that the EEC relay is working).
eholt80
