Blower motor resistor wiring
-mikko-
Some previous (idiot :angry: ) has cut these blower motor resistor wires and try to put there wrong resistor!!!
I bought correct resistor and now I need some help, could someone look under the bonnet and tell me, which color goes where?
There is four wires: red orange yellow and green, and in resistor there is two pins side by side and two of them are below them.
Hopefully someone understand what I mean B)
Car is -88 if that matters...
Here is the diagram from an 83 Bronco. It should be good for all years since Ford does not reinvent the wheel too often :rolleyes: The colors of the wires are shown ie. O/Bk = Orange with black stripe.
M
-mikko-
Thank´s but I believe that sometimes between 1983- 1988 Ford actually reinvent wheel :p /emoticons/[email protected] 2x" width="20" height="20" /> because my car has 4 differend speed in blower.
Resistor is like this (photo found in internet...)!
BroncoJoe19
That connector does not match the one in my 1990, so I can't give any specific help.
ALl that I can offer is that the resistor is on the ground side of the circuit. The more resistance, the slower the fan/blower will spin. In my '90 there is also a "thermal limiter" in the resistor. I don't know how to determine which lug goes to it.
This diagram may be helpful.
My current suggestion is to go to a junk yard and cut off the connector from one of the Broncos there leaving plenty of wire to splice to your wires. You should be able to match color for color.
Look at what VoltsAndBolts did in his 87
colors are =
Read his entire Conn. Repair & Modification in an 87
Source: by VoltsAndBolts (expendable) at http://www.supermotors.net/vehicles/registry/9954/58987
w/more wire color pics too
GL!
The problem I have with that solution is that it doesn't use a proper connector and ergo easy for those to come off since they are not latched in. However, it is better than, "a stick in the eye", but I would still recommend getting a proper connector ASAP.
yo Fred,
I agree, that isn't what I'd do either, but I posted it for the wiring colors.
Here is one source and I need to have someone confirm that it is correct for the year Range;
A/C Blower Motor Resistor Socket
1984 - Up
Fits resistor E7TZ19A706A (see below)
4-14 gauge leads
since BZ won't allow the Images to appear here;
or image @ http://ken-co.com/images/fmsi/51783.jpg
Kenco part # 51783
or @ http://www.autozone.com/autozone/accessories/Santech-Ford-A-C-blower-motor-resistor-pigtail/_/N-269a;jsessionid=A16E761C4A978170E66314012563EDE4.diyprod5-b2c10?counter=2&itemIdentifier=930103_0_0_
Part Number: MT0905
Weight: 0.087 lbs
Type: A/C Pigtail
Contact Terminal Material: Steel
Automotive Electrical Terminal Type: Spade
Length (In): 3
Number Of Wires: 4
Package Contents: Pigtail - Ford A/C Blower Motor Resistor
Pigtail Wire Gauges: 16
Special Fitment Information: NA
Terminal Gender: Female
Shipping Information: Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
or;
Replacement Ford A/C Blower & Heater Switch Sockets blower. Motor resistor#E7TZ-19A06-A.
For Ford trucks 1986-1994.
764444 Ford socket connector for A/C blower. Motor resistor#E7TZ-19A06-A.
https://www.elecdirect.com/Data/ProductPDFs/97-99ta.pdf
#764444
same for da R pack;
[http://www.rockauto.com/catalog/moreinfo.php?pk=2395568Alternate/OEM Part Number(s): 4C2Z19A706BA, E7TZ19A706A
$18.15
or, pick out the correct R at the NAPA site; I got over 15 pages of hits on it with a search
yo M,
YW
and are the colors and positions by by VoltsAndBolts exactly the same as in your year?
Same for the connector by ken-co.com,etc.?
seve
