Jump to content
Carburetor for 74 Bronco
3 replies to this topic
#1 janroger64
janroger64
    Duck Tape L'fixer :)
  • Members
  • PipPip
  • 11 posts
Posted 26 March 2010 - 03:02 PM
Going to get a rebuilt carburetor for my 74 Bronco with a 302 engine. It's got the Motorcraft 2100 2-v carburetor. Been looking at the web pages for several companies in the US. Since I live in Europe, I'll have to buy a rebuilt carburetor rather then having the one on my Bronco rebuilt. The waiting time will bee too long. Been checking out these companies; http://www.carburetorexchange.com , http://www.nationalcarburetors.com ,
http://www.carbsonly.com . Anybody out there have a review on any of these companies and the quality of their procucts? Since I live where I do, I need to make my purchase from a reliable vendor. Thanks, janroger64.
#2 Bully Bob
  • Moderators
  • PipPipPipPipPipPipPipPip
  • 3834 posts
  • Gender:Male
  • Interests:Going nose-to-grill with GIANT Bulls here in the high desert.
    Hence-forth my given C.B. trail handle;
    "Bully Bob"
    Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
  • Favorite Bronco Year?:6677
Posted 27 March 2010 - 03:26 PM
Hi Jan.,
No one is answering., nor am I familiar with those rebuilders. :unsure:
I can tell you., it's best to have yours re-built if the throttle shaft is NOT wobbly & the top screws aren't stripped.
That's a good carb. choice. It's real easy to re-build.
Trading for a re-built is a "luck of the draw" ....it's likely you'll get a good one, but who knows.
Lastly, R/U sure the carb is the problem...?
Swapping in another carb., & the performance still isn't there, you then have to fig. out if you got a bad carb., or the problem is elsewhere. :-B
HTH
---Jeep recovery unit---
1966 "U-13" Roadster...topless, doorless. (with rag top-n-doors)
200 cu.in. I-6 with 250 head.
$30 homemade HEI elect. ignition.
Full roll-cage, front.
70+ MPH cruise---15 MPG
6 EB's (& 11 early Land Cruisers) referbished & sold..
#3 janroger64
janroger64
  • Members
  • PipPip
  • 11 posts
Posted 30 March 2010 - 12:04 AM
Hi Bob. Thank's for your answer. The reason I'm looking for another carb is that gas is leaking out between the throttle shaft and the body. I guess the bushings for the shaft are badly worn... :mellow: Other than that it works fine. Could always get a kit and rebuild it, but the leakage would still be there... :( All of these rebuilders claim that they put new bushings in the carburetors they rebuild. If I go with one of these I'd like to get one that's been rebuilt in the US.
#4 Bully Bob
  • Moderators
  • 3834 posts
  • Gender:Male
    "Bully Bob"
Posted 30 March 2010 - 07:00 AM
You should be fine with a re-built...
However., a carb can't leak per-se' unless it's cracked internally.
A faulty needle & seat &/or a "too high" float setting will do as you describe as well.
Liquid fuel never meets that shaft, while running or at rest. And that shaft is not air tight.
Even a new carb. would seep fuel out there if the fuel bowl settings were incorrect or faulty.
Hope all's well there 'cross the pond., & do post your decision/results.
HTH
Reply to this topic
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
