Ford Bronco Zone Early Bronco Classic FullSize Broncos: hard to start and slugish - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
#1 User is offline   89purple horse
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
  • Interests:hunting fishing campin mudin and workin on my baby
Posted 15 March 2010 - 10:37 PM
the purple horse is a 89 with a efi 351. when its cold it fires up just fine and ready to run. runs pretty good untill it warms up then it seems slugish i dont get no check engine light or anything. could that be egr? gas inlet tube off manifold broke during header swap and have not been able to replace it yet. the other thing is its hard to start when its hot it acts if the battery is weak but its only a month or 2 old. i am leaning towards its in timing some where but i am new at the tfi system can so one help someone help out a lost shade tree mechanic
89 efi 351 w/c6 eddie bauer. fresh paint and fresh motor. 6 inch rough country sus. lift .33x12.50's. b&m street/strip shift kit. shorty headers cat back exhaust . some minor tricks to help the heads, intake flo just a little bit better and keep the fuel cooler. 2 kicker comp 12 inch subs 700w rockford fosgate punch amp. Carr light bar with 4 kc day lighters
#2 User is offline   miesk5
  • Use Ford parts, let da ZONE handle ice scrapers
  • PipPipPipPipPipPipPipPip
  • Group: Members
  • Gender:Male
  • Interests:Off roading, fishing, beaches, military, breaking metal parts
Posted 16 March 2010 - 05:06 AM
yo PH!
Welcome to da ZONE!
Have charging & starting sys tested for Free at a local parts store.
I'd do a Self Test for Diagnostic Trouble Codes (DTCs)anyway, such as this by our good friend, BroncoJoe http://broncozone.co...587&#entry74587
I run it around to heat the engine up and shift thru all gears incl Reverse.
then; turn off all accesories/lights, etc.
Do KOEO portion first
For Key On Engine Running (KOER) portion, the engine has to be @ normal operating temp.
Posat any codes found here or look em up in my broncolinks.com site.
Check Timing;
Adjustment in Ford EFI Engines
Source: by Ryan M (Fireguy50) at http://fordfuelinjec.../index.php?p=71
Scroll down to; HOW TO CHECK AND SET TIMING
your SPOUT connector is @ Distr; such as here;
Spark Output (SPOUT) Connector Location pic @ distributor in an 88
Source: by Jem270 at http://www.supermoto...ry/media/249442
Posted Image
Of course there are more that could be tested; do that stuff first
GL!
See our Big Bronco Technical/Mods, Parts Sources & Technical Service Bulletins Links site
96 Bronco, E4OD, Man Xfer Case & Hubs
Thanks to All Who Serve
#3 User is offline   89purple horse
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 18 March 2010 - 09:16 PM
quote name='miesk5' date='16 March 2010 - 07:06 AM' timestamp='1268744789' post='105724']
yo PH!
Welcome to da ZONE!
Check Timing;
Posted Image
GL!
[/quote]
thank you very much for your time miesk u were right i pulled the spout connector and re timed it and it ran like a champ for a couple days. and now i think i am having starter issues cause now if i go on long drives and shut it off it will barly turn it over (but runs awesome). i have read in some threads that maybe the headers r causing the starter to get to hot. can some one verify that for me ??
#4 User is offline   Justshootme84
  • Supreme Commander
  • Group: Moderators
  • Gender:Male
  • Interests:4wd trucks, hunting, fishing, music
Posted 18 March 2010 - 09:58 PM
Yes, that's quite possible that the headers are overheating the starter. You can try putting a heat shield over the starter, or wrapping the headers. JSM84
1984 Bronco XLT, 460, C-6 AT, Dana60, Sterling 10.25", 36" GYR RT-II's on H1 rims, S&W Racecars 10-pt cage kit, PRP racing seats, tube doors, Herculiner, custom "shaker" assembly.
1988 Bronco Custom, 302 EFI, C-6 AT, Ford 8.8". parting out
1986 Bronco Custom, 300-I6, NP435 4sp, Ford 8.8", new paint
1988 F-350, 4WD, 460 EFI, C-6Dana 60, Sterling 10.25 (donor)
1978 Bronco Custom, 351M, NP435, Currie Ford 9" w/ spool
1979 F-150 4WD, 351M, C-6, 4.10 gears w/ 35" mud tires
Posted Image
#5 User is offline   89purple horse
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 18 March 2010 - 10:04 PM
ok thanks for the info. i am out of work right now and times r kinda tight and the header wrap is pretty spendy but a buddy has some extra that would probly cover the starter think that would work?
#6 User is offline   miesk5
  • Group: Members
  • Gender:Male
Posted 19 March 2010 - 05:04 AM
yo!
Thanks for coming back to update!
Yes, you can use that wrap as well as anythAng else you can scrounge up around the house incl pieces of appliance case steel or ss; look at the cat converter's heat shield; same principle.
GL!
#7 User is offline   RBuffordTJ
  • Bronco Pimp
  • View blog
  • Group: Members
  • Gender:Male
  • Interests:My new 4x4 toy, it's a 1984 Bronco. I like campin', swimmin', readin', rasslin' (aka wrestling) and shooting. I do woodworking for enjoyment and sometimes money.
Posted 19 March 2010 - 08:12 AM
[/quote]thank you very much for your time miesk u were right i pulled the spout connector and re timed it and it ran like a champ for a couple days. and now i think i am having starter issues cause now if i go on long drives and shut it off it will barly turn it over (but runs awesome). i have read in some threads that maybe the headers r causing the starter to get to hot. can some one verify that for me ??
[/quote]
One other thing to check is your ground cables. Mine had corrosion inside the cable from years of being on and as it got warmer it got harder to start. A new ground cable stopped it from a sluggish restart when it was hot.
Rick in Orlando
1984 Bronco XLT
351 Windsor
Pro Comp Steel Rock Crawler Wheels
Pro Comp Mud Terrains 33"x12.5
Ceramic Headman Long Tube Headers & True Dual Exhaust
His name is "Justice"!
Posted Image
In Memory of my son, Garion Michael Barber
#8 User is offline   89purple horse
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 19 March 2010 - 01:36 PM
[/quote]
Rick in Orlando
[/quote]
will do rick and miesk thanks
Page 1 of 1
Fast Reply
