Ford Bronco Zone Early Bronco Classic FullSize Broncos: my bronco is sick - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
my bronco is sick
#1 User is offline   motox19
  • Where's My Hammer!?!
  • Pip
  • Group: Members
Posted 07 February 2010 - 06:15 PM
i have a 95 full size , if i put the peddle to the floor it wont rev over 3500 and pops thru the intake. if i dont put it to the floor it will rev like normal. after this problem started i gave it a complete tune up but it still does this. its not showing any TDC'S. im out of ideas. down to thinking that it may have a clogged cat converter.does any body have an idea on this matter? any help i can get will be greatly appreciated
#2 User is offline   BroncoJoe19
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 07 February 2010 - 06:51 PM
a clogged cat was my first thought.
BroncoJoe19... I am not a professional mechanic, nor an engineer.
One should always obtain professional advice before attempting a repair or modification.
1990 Tan on Black Eddie Bauer - resides in North Jersey
302 with 33's on 15s E4OD Speedometer corrected trans
Auto hubs with manual transfer case snorkel
#3 User is offline   BroncoJoe19
  • Supreme Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 07 February 2010 - 06:53 PM
HowTo diagnose a plugged catalytic converter
http://www.ford-foru...html#post165883
#4 User is offline   motox19
  • Pip
  • Group: Members
Posted 07 February 2010 - 07:09 PM
i will try that tomorrow, thanks for the info
#5 User is offline   BroncoJoe19
  • Supreme Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 07 February 2010 - 07:37 PM
I've never tried that, please let me know how it works out.
#6 User is offline   motox19
  • Pip
  • Group: Members
Posted 08 February 2010 - 02:14 PM
i will try it and let you know . its snowing and cold here in kansas city so im not messin with it today ..lol
#7 User is offline   motox19
  • Pip
  • Group: Members
Posted 28 February 2010 - 05:36 PM
well i finaly got a vacuum gauge and tried that, tried it on 3 different motors, the bronco had 17 inch pounds at idle and lost 3 inch pounds at 2500 rpm, my s-10 lost 1 inch pound and my camaro gained 4 inch pounds. the s-10 and camaro run perfect. so im not sure if that is a good way to test but will cut a hole in front of the cat and see if that is truly the problem
#8 User is online   miesk5
  • Use Ford parts, let da ZONE handle ice scrapers
  • Group: Members
  • Gender:Male
  • Interests:Off roading, fishing, beaches, military, breaking metal parts
Posted 02 March 2010 - 05:59 AM
yo; before you open it up; how about removing it?
aww. I can't see your year info in reply mode!
On my 96 I have basically 2 cats; a reduction & oxidation -
Use PB Bl;aster; etc. liberally on all fittings for O2 sensor, air tube, and clamps (the muffler clamp came off ezily on my 96 2 weeks ago! after 14 years and 2 months on it!
Here is a pic showing some of the fittings by Steve83
http://www.supermoto...try/media/71635
some more vac gauge test info;
"...The easiest test for converter plugging is done with a vacuum gauge. Connect the gauge to a source of intake vacuum on the intake manifold, carburetor or throttle body. Note the reading at idle, then raise and hold engine speed at 2,500. The needle will drop when you first open the throttle, but should then rise and stabilize. If the vacuum reading starts to drop, pressure may be backing up in the exhaust system....If there appears to be an exhaust restriction, disconnect the exhaust pipe (MIESK5 NOTE; or Muffler) just aft of the converter to relieve pressure and recheck the readings. CAUTION: The pipes will be hot so wait awhile for things to cool down. If vacuum goes up and/or backpressure drops, the problem isn't not a plugged converter but a plugged muffler or collapsed pipe. If there's little or no change in readings, the converter is plugged..."
Test, General
Source: by autos.yahoo.com http://autos.yahoo.c.../ques083_0.html
and;Vacuum Test, General (Click Inspections); Vacuum Test, General (Click Inspections);
"...You may also take the converter off the vehicle and check it for damage or clogging. Shining a flashlight into the core of a honeycomb style converter will reveal whether the honeycomb is partially clogged, damaged, or loose from the edges...."
by walkerexhaust.com
See our Big Bronco Technical/Mods, Parts Sources & Technical Service Bulletins Links site
96 Bronco, E4OD, Man Xfer Case & Hubs
Thanks to All Who Serve
#9 User is offline   motox19
  • Pip
  • Group: Members
Posted 02 March 2010 - 04:06 PM
its a 95
#10 User is online   50joe
  • Bronco Pimp
  • View gallery
  • Group: Members
  • Gender:Male
Posted 02 March 2010 - 04:16 PM
I seriously doubt its the cats. I looked this morning at the vacuum gauge i have installed in my truck and my readings were pretty much the same. If its only at wide open throttle, but will rev through the power band at anything less, it sounds more like either a faulty TPS, or a lack of fuel. Reading codes is a great help sometimes, but just because the ECM doesn't throw one, doesn't mean a sensor is not bad. If you can get acess to a scanner that will read a data stream, it will be a big help. I know not everyone has acess to these things, but you would be surprised at how many sensors will act up, and the vehicles computer doesn't pick up on it. Especially pre OBD-II.
Almost anything can be fixed with a little know how, a case of beer, a roll of gorilla tape, and a really BIG hammer.
96 XLT 5.0, 3" single exhaust with flowmaster, WARN premium locking hubs,305/70/16 BFG All Terrains,3" body lift, 8.8 with Ford racing trac-lok, fast-trac soft-top, 170amp Alternator from Summit, a few rattles, couple squeaks, some dents, buncha crap I dont really need, but think is cool.
http://www.teamaggre...x4.com/Stevo76/
#11 User is offline   motox19
  • Pip
  • Group: Members
Posted 02 March 2010 - 05:13 PM
will the code reader from orielly auto parts read it or only if it has the engine light on ?
#12 User is offline   brad050
  • Bronco Maniac
  • PipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 25 March 2010 - 04:54 AM
Good reason to remove it :D
Posted Image
Page 1 of 1
Fast Reply
