Ford Bronco Zone Early Bronco Classic FullSize Broncos: air pump 1995 351 - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
air pump 1995 351 air pump 1995 351
#1 User is offline   freeeat40
  • Where's My Hammer!?!
  • Pip
  • Group: Members
Posted 11 January 2010 - 12:06 PM
I hope someone can shed some light on this. I have a 1995 Bronco with a 351 engine. There is something called the "Air Pump" mounted on the front bottom of the motor, and my fan belt goes through it. Evidently the bearings or something is going out, squeeking real bad, and needs to be replaced. But the tech at Napa told me that some people totally remove this and just install a shorter fan belt.
Does my motor NEED this air pump?
If I remove it totally, does anyone know what size belt I would need to use?
Any and all help is appreciated.
#2 User is offline   Bronc76
  • Bronco Commander
  • PipPipPipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 11 January 2010 - 01:25 PM
Does your state have emissions testing?
#3 User is offline   blueox89
  • Bronco Newbie
  • View gallery
  • Group: Members
  • Gender:Male
Posted 11 January 2010 - 02:53 PM
If you do have to keep your truck emissions legal the air pump comes apart pretty easy, and you can lube them up with about an hour or two worth of work. My '89 5.0 sat for a while and when I went to start it the air pump was squealing bad. All you need to do is pull it out,remove the pulley bolts (10mm) with an impact, pull the back bolts and pry the case apart with a screw driver and persuasion (or in my case a rubber mallet). Once you pull it apart you can spray it down with lube and wipe out any gunk with a cloth. When you go to assemble it make sure to get the shaft on the rear cover through all four sets of bearings that connect to the impeller blades. You should be able to spin the pump by hand and feel air come from the outlet tube. I just went through all of this last weekend, its a hell off a lot cheaper to pull it apart than buy a new one for $120 at O'reilly's. hope this helps.
#4 User is offline   Bronc76
  • Bronco Commander
  • View blog
  • Group: Members
  • Gender:Male
Posted 11 January 2010 - 05:12 PM
I agree with blue, it would be cheaper to fix, but I wouldn't throw it away either. Some of these parts are getting hard to find.
#5 User is offline   freeeat40
  • Pip
  • Group: Members
Posted 11 January 2010 - 06:57 PM
Cool!! I don't have to worry about it in my state. But I don't really want to keep up with a different size belt that what is supposed to go on there.
Taking it apart sounds like a much better idea.
Thanks guys.
#6 User is offline   Chrish_jr
  • Duck Tape L'fixer :)
  • PipPip
  • Group: Members
  • Gender:Male
  • Interests:current rig:<br />1976 Jeep CJ5, 355 chevy, 3sp man, twin stick transfer, 4&quot;TC lift, 1&quot; os greeseable shackles, 35&quot; mud king xts on 15x10 rims.<br /><br />Rig in works:<br />1994 EB bronco 5.8L
Posted 11 January 2010 - 09:48 PM
someone correct me if I'm wrong, but isnt there a replacement pully assembly you could buy to delete the air pump allowing the use of the standard belt? I could be wrong, but thought I ran across that somewhere.
Not much help I know, but if there is such an assembly, that could also be an option for you
#7 User is online   Seabronc
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Moderators
  • Gender:Male
Posted 12 January 2010 - 10:48 AM
If you remove it you will most likely never pass an emissions test. One of it's main functions is to add oxygen to the CAT in order to allow it to burn off some of the pollutants caused by the combustion process. In the majority of the states, modification of the emissions control system is illegal except for, "Off road only", vehicles and "track only" vehicles. Those are a set of laws that are not strictly enforced and they are backed by Federal law. Just like cell phone laws they are in the list of things the police can get you for it they need extra revenue for the month. However, if you are in a state like California, they are strictly enforced. It's no big deal when you are in a largely rural area, but when you get into high density areas it becomes a major health problem for everyone including the owner of the polluting vehicle.
OK, off my soap box, it's your truck but I would recommend getting it fixed.
Fred
Parts replacement is not trouble shooting, replacement follows trouble shooting
Broncos are MPVs not SUVs
Communication: I know you think you know what I said, but what you need to know is, I didn't say what I meant.
Some of my pictures at Supermotors http://www.supermotors.net/212
1983 Full Size Bronco with; Ford 8.8" 3.08:1 Rear; Dana 44 3.08:1 Front; WARN Premium locking hubs; 31x10.5's; NP208; Holley 4160 4bbl; MSD 6AL Ignition; MSD Blaster 2 coil;
1978 Saginaw Pump V-Belt Power Steering;
1984 F150 Dash;
1985 351W HO;
1985 Tilt steering wheel;
1993 Mercury Sable 3G 130 Amp Alternator;
1995 F150 doors;
1995 20 inches of rear portion of the tub;
1996 Bronco tail gate;
1996 Eddie Bower Over Head Console;
1996 Lincoln Mark VIII 4200 CFM Electric Fan;
Headlight harness upgrade; DRLs; Battery relocated to rear; Under hood fuse box vs fusible links; Upgraded wiring for rear window to 10 AWG;
Always under restoration
#8 User is offline   pav_89Bronco
  • Bronco Newbie
  • Group: Members
Posted 18 March 2010 - 02:04 AM
Hi. I know I'm jumping on this late, but I have an 89 with the 5.8, and my AIR system is broken. just behind the engine, almost in the center, there is a hose that is disconnected. It is a rubber hose that should be connecting to a piece of metal that connects the two exhaust banks together, but the connection has rusted thru. WHere can I get these parts (The metal piece and the hose, or does somebody have a suggestio for a work-around. Not like to bypass emissions, but I mean I don't care if it's factory as long as it works. I live in a state where emissions tests aren't done, but from reading these posts it looks like I want to keep this in place and functional. ANy help is greatly appreciated. Thank you.
89_Bronco_Beast
#9 User is online   miesk5
  • Use Ford parts, let da ZONE handle ice scrapers
  • Group: Members
  • Gender:Male
  • Interests:Off roading, fishing, beaches, military, breaking metal parts
Posted 18 March 2010 - 04:51 AM
yo pav;
Look at these pics/diagram;
Posted Image
Crossover Tube, Diverter & Check Valves & Hoses Location Diagram in a 5.8
Crossover Tube, Diverter & Check Valve pic in an 88 5.0 Source: by Jem270 at SuperMotors.net
Posted Image
Posted Image
Source: by 95F350XL (Chris) at fordtruckfanatics.com
http://i214.photobuc...co/IMG_0418.jpg
Diverter & Bypass Valves, Hoses, Crossover Tube, EGR Valve, PCV Port & Smog Pump Location pic in an 88 F 150 5.0
Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
Posted Image
Secondary Air Injection System Diagram & Overview; by Steve
Posted Image
Secondary Air Injection system consists of a belt-driven Air Pump, single or dual AIR Diverter valve(s), an AIR Bypass valve, and AIR Bypass solenoids, air silencer/filter, Powertrain Control Module and connecting wires and vacuum hoses. The Belt-Driven Secondary Air Injection system provides either upstream/bypass air or upstream/downstream/bypass air. The number of these system configurations vary significantly with AIR Bypass and AIR Diverter valve combinations (Figure 179).
2. The PCM provides one or more signals that enable one or more AIR Bypass solenoids. 3. The AIR Bypass solenoids control one or more AIR Bypass valves and/or AIR Bypass Diverter Valves in order to route secondary air depending upon the specific configuration. 4. The belt-driven Air Pump is operational any time the engine is running.
read more @ http://www.supermoto...ry/media/589993
Avail @ NAPA; or direct thru Manufacturer; PCI
Call PCI; great customer service!; and you can e mail em with the pic or diagram of what you need.
GL!
This post has been edited by miesk5: 18 March 2010 - 05:01 AM
See our Big Bronco Technical/Mods, Parts Sources & Technical Service Bulletins Links site
96 Bronco, E4OD, Man Xfer Case & Hubs
Thanks to All Who Serve
#10 User is offline   pav_89Bronco
  • Bronco Newbie
  • Group: Members
Posted 19 March 2010 - 11:00 AM
miesk5,
thank you! fantastic information, pictures and links. This helps tremendously. I think I've decided to buy the parts necessary to keep everything functioning. I'm also going to get a new cat to help keep things cleaner for everyone. Thanks again.
pav
#11 User is online   miesk5
  • Group: Members
  • Gender:Male
Posted 19 March 2010 - 11:56 AM
yw! And glad you came back here too.
And it's good that you'll get it back in-order; that helps air quality... which is no joke in LA and a lot of other places; and it will help the Bronco run a ok and make it possible to diagnose future problems ezier.
As for the cat; http://www.walkerexhaust.com
Here it is for your Bronco;
Walker Online Catalog
49-State (EPA) Converters Look-up
1989 Ford Bronco
Description:
8 - 5.8L Front & Rear
15142 37
Replaces Both Front and Rear Converters
8 - 5.8L Front & Rear 16120 25,37
8 - 5.8L Rear
15042 37
37 Fed. & Calif. Emiss. Models. Not legal for sale on vehicles licensed in the State of California.
25 Replaces Multiple O.E. Converters. Only Failed Converters May Be Replaced. See Catalytic Converter Installation Guide.
Part Number: 15142
Inlet Size/Configuration 2-1/2"
Outlet Size/Configuration 2-1/2"
Overall Length 18"
Catalytic Converter Type 2 Way/3 Way/3 Way + Air
Body Type Large Oval
Contents
Type Universal
Features & Benefits Designed for aftermarket Pre-OBDII requirements in 49 states and CANADA
Best Balance of Performance and Price, Broad application coverage, Stainless steel body, Aluminized expandable bushings and heat shields
May Require Modifications to Complete Installation.
Posted Image
$123.99 @ JEGS
2.5'' In/Out, 18'' Long
15142 - Walker Super Converter
At Summit it is $125.95
Part Number: 16120
Inlet Size/Configuration 2"
Outlet Size/Configuration 2-1/4"
Overall Length 58"
Contents
Location Main
Type Direct Fit
Features & Benefits O.E.-Style and design for quick "bolt-on" installation. Premium Quality Materials and Construction.
Posted Image
Price; one good source is rockauto.com
WALKER Part # 16120 {***No Longer Legal for Use in California***; Direct Fit}
Category: Catalytic Converter
$340.79
At Summitit is $351.69
I get www search prices such as above & then try to get local places to match or beat those prices incl S&H and taxes.
But, nearly all da mom & pop parts stores are gone around here now so; the local chain stores don't bargain. or their sales help is clueless and too busy.
Page 1 of 1
Fast Reply
