Jump to content
Back window wiring!!! need help!!!
10 replies to this topic
#1 BigGreenBronco
BigGreenBronco
    Bronco Maniac
  • Members
  • PipPipPipPipPip
  • 104 posts
  • Gender:Male
Posted 22 November 2009 - 03:09 PM
I recently fixed my back window so that it would go up and down, but unfortanatly the switch does not work. I got a switch out of a bronco at a pick n pull and put it in but still it wont work from the dash or the key switch. I tested with the wires where they go into the tailgate(next tothe reverse light) and both purples wires have power. Then i ran jumper wires between there and the motor but still the switch will not move them. Just to make sure the switch works i tested the wires that come out of it and they have power when they are supposed to. The thing i noticed was neither purple wires have power next to the reverse light when i pressed up on the switch. Any ideas guys????? Is it possible i dont have enough power goin from the fuse to the motor to work it?
1995 Bronco XL 302 efi 4.56 gears dual exhaust
1986 chevy camaro aftermarket 350 holley carb dual exhaust
#2 Krafty
Krafty
    Supreme Commander
  • Members
  • PipPipPipPipPipPipPipPip
  • 1049 posts
  • Gender:Male
  • Favorite Bronco Year?:1981
Posted 22 November 2009 - 03:24 PM
did you look at your safety switch in the tailgate? that may be the culprit.
81 Bronco 300 4spd, 4" skyjacker coils in front, 3" add a leaf by trailmaster in rear, and 2" blocks. 33x12.5x15, Sold my baby. ( I bought it when I was 13, hit the first mud hole at 14 ,did the first lift when I was 16)
89 F-150 302 efi 4x4 swapped the motor but had a bunch of problems sold for 500
79 Ford Thunderbird 429 swap summer car, Traded For Plymouth
93 F150 4.9 4x4 reg cab long box ,31x10.5x15 and custom bush bar, sold to young guy as a winterbeater
73 Plymouth Fury II 2dr Hardtop 318 auto
87 Z28 Camaro 350 with Nitrous
01 Dakota 3.9 5spd 4x4 Daily
83 Yamaha xj750 Seca fair weather toy.
07 Ford Escape (wife's Daily)
#3 BigGreenBronco
BigGreenBronco
    Bronco Maniac
  • Members
  • PipPipPipPipPip
  • 104 posts
  • Gender:Male
Posted 22 November 2009 - 03:48 PM
but if i ran two wires from the outdside of the tailgate wouldnt that bypass the saftey switch?
#4 Krafty
Krafty
    Supreme Commander
  • Members
  • 1049 posts
  • Gender:Male
Posted 22 November 2009 - 04:13 PM
are you sure your motor is working?, if you jumped the motor to a power source and still nothing then your motor is fried, check for power at the harness that goes to the motor when the switches are activated.
did you say that when you used the switch, you didn't have power at the wires going into the switch?, but you did before you used the switch?
#5 BigGreenBronco
BigGreenBronco
    Bronco Maniac
  • Members
  • PipPipPipPipPip
  • 104 posts
  • Gender:Male
Posted 22 November 2009 - 04:34 PM
No my motor is fine I run a power wire from my fuse box to the motor and hook everything up as normal when i turn the ignition it goes down then i reverse the wires and it goes up. In the dash when the switch is not pressed only two blue and black wires have power then when i press down or up a purple wire has power. right outside the tailgate there is a black and blue wire, 2 purple wires, a black wire and a black and white wire. without the truck on both purple wires nd the black and white wire have power. when i turn the truck on its the same then when i press down on the switch it the same finally when i press up only the black nd white wire have power. Would a missing fuse or broken one in the distributor box not send enough power to the motor?
#6 Krafty
Krafty
    Supreme Commander
  • Members
  • 1049 posts
  • Gender:Male
Posted 22 November 2009 - 05:06 PM
no your fuse panel is fine. this is what I see when I look at the wiring diagram. you have lt blue and black going to dash switch for power, power there is fine
you have black and white going to key switch power is fine.
so what exaclty is the problem? both dash and key switch won't make it move, or they both will make it go down just not up? or only one switch works and the other doesn't? the purple wires get power and act as a ground through the dash switch depending on which way they are positioned. in the key switch the purple wires only act as grounds.
#7 BigGreenBronco
BigGreenBronco
    Bronco Maniac
  • Members
  • PipPipPipPipPip
  • 104 posts
  • Gender:Male
Posted 22 November 2009 - 05:58 PM
i dont think the dash switch is broken because it changes which purple wire has power in the dash. from the switch in the dash i have 6 wires 2 blue/black which are in the same slot, 2 purple wires one is purple/light bue the other is purple/green then i have a thick black wire and a thin black wire. Im not sure how many volts im gettn in the tailgate but i am gettn some. I just tested the wire goin to the motor and both have power isnt there a mechanism that detects if the glass is too far up or down if that failed maybe i just need to bypass it
#8 50joe
50joe
    Bronco Pimp
  • Members
  • 380 posts
  • Gender:Male
Posted 22 November 2009 - 06:31 PM
The latch on the drivers side will prevent the window from working if thae safety switch isn't working or is out of adjustment.
Almost anything can be fixed with a little know how, a case of beer, a roll of gorilla tape, and a really BIG hammer.
96 XLT 5.0, 3" single exhaust with flowmaster, WARN premium locking hubs,305/70/16 BFG All Terrains,3" body lift, 8.8 with Ford racing trac-lok, fast-trac soft-top, 170amp Alternator from Summit, a few rattles, couple squeaks, some dents, buncha crap I dont really need, but think is cool.
http://www.teamaggre...x4.com/Stevo76/
#9 BigGreenBronco
BigGreenBronco
    Bronco Maniac
  • Members
  • PipPipPipPipPip
  • 104 posts
  • Gender:Male
Posted 22 November 2009 - 06:47 PM
Does anybody know how i can bypass or fix the switch and latch? thats the only thing i know that would prevent my window from workn
#10 Krafty
Krafty
    Supreme Commander
  • Members
  • 1049 posts
  • Gender:Male
Posted 23 November 2009 - 04:51 AM
find the two wires going to the safety switch in the tailgate. cut them strip them back and wire them together and seal with shrink wrap tube. then it will never fail again. just make sure the tailgate is properly closed every time before you put the window up.
#11 BigGreenBronco
BigGreenBronco
    Bronco Maniac
  • Members
  • PipPipPipPipPip
  • 104 posts
  • Gender:Male
Posted 23 November 2009 - 03:56 PM
today i bypassed the switch and wrapped it it worked. thanks for the help guys this will make my bronco more enjoyable
Reply to this topic
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
