Headlights turn OFF
#2
Posted 21 November 2009 - 08:58 AM
Sorry had to say that.. I would check your headlight switch and if that is ok, check the grounds. Does all of your lights turn on and off or just your headlights?
#3
Posted 22 November 2009 - 06:56 AM
#4
Posted 22 November 2009 - 07:08 AM
and please don't double post the same issue, from now on keep to posting in one of the areas with a topic,
thanks, and good luck
This post has been edited by Krafty: 22 November 2009 - 07:10 AM
81 Bronco 300 4spd, 4" skyjacker coils in front, 3" add a leaf by trailmaster in rear, and 2" blocks. 33x12.5x15, Sold my baby.
81 F150 swapped 390 with broken frame, scrapped the truck but kept the motor then sold it later for $500
88 GMC 3500 flatbed dually, 350 swap, scrapped the truck but kept the motor, now in 88 Camero Drag car
95 GMC 2500 ext cab, seized 6.5 with blown tranny and transfercase, sold for $500 with a mint body.
89 F-150 302 efi 4x4 Shortbox restored (mostly)
79 Ford Thunderbird 429 swap summer/ drag car. rebuilt motor and trans, Haven't lost yet.
69 Mustang 302 4 spd original numbers matching, red/black.
#5
Posted 22 November 2009 - 07:23 AM
#6
Posted 24 November 2009 - 06:49 AM
stay on. This problem happened at the same time that my dash stopped
lighting up and there is no dinging sound anymore that reminds me when
I leave the lights on. I checked the fuses and they are fine. Any
suggestions?
#7
Posted 30 November 2009 - 03:56 PM
suggestions?
I have 2 Buick,s that had the lights go out --in the same curve --and I made it home and had to change the light switch. If the swich is good,the dimmer is good,the ground is clean and tight---you might want to check where the outside wireing harness goes together into the wireing harness inside the cab. The stuff the manufactureing companys put on the junction to keep out moisture---will sometimes get hot (dureing summer months ) and cause you to loose your connection. What we done was take the bolt out that holds the wireing together (on the firewall) and clean the connection out really good with gas or a good cleaner---now--make sure that it is completely dry------like in a day or so --before you connect it back up---AND MAKE SURE YOU TAKE THE BATTERY TERMINAL OFF--BETTER YET--TAKE THE BATTERY OUT ,SO NO ONE WILL PUT IT BACK ON ---TO AVOID A FIRE.
#8
Posted 30 November 2009 - 06:13 PM
'91 XLT 302 32" BFGs MB rims ProRyder Shocks 1.5" Susp Lift 1.5" Body Lift Superstock Ignition Hedman Headers Flowmasters Muffler AutoLocker Hubs Sony Stereo Leaky Rear Main Seal Bent Back Bumper
#9
Posted 30 January 2010 - 03:44 PM
wes393, on 30 November 2009 - 07:13 PM, said:
Years ago my '79 would do this. Eventually it led to the headlights virtually exploding. The problem wa the ground between the engine, and body/frame was loose. When it would short the headlights would go out.
#10
Posted 30 January 2010 - 04:52 PM
Parts replacement is not trouble shooting, replacement follows trouble shooting
Broncos are MPVs not SUVs
Communication: I know you think you know what I said, but what you need to know is, I didn't say what I meant.
Some of my pictures at Supermotors http://www.supermotors.net/212
1983 Full Size Bronco with; Ford 8.8" 3.08:1 Rear; Dana 44 3.08:1 Front; WARN Premium locking hubs; 31x10.5's; NP208; Holley 4160 4bbl; MSD 6AL Ignition; MSD Blaster 2 coil;
1978 Saginaw Pump V-Belt Power Steering;
1984 F150 Dash;
1985 351W HO;
1985 Tilt steering wheel;
1993 Mercury Sable 3G 130 Amp Alternator;
1995 F150 doors;
1995 20 inches of rear portion of the tub;
1996 Bronco tail gate;
1996 Eddie Bower Over Head Console;
1996 Lincoln Mark VIII 4200 CFM Electric Fan;
Headlight harness upgrade; DRLs; Battery relocated to rear; Under hood fuse box vs fusible links; Upgraded wiring for rear window to 10 AWG;
Always under restoration
#11
Posted 31 January 2010 - 07:05 AM
351 M
Headers
Dual 3 inch exhaust
C6 Trans
Eledbrock intake
600 holley
DUI distributor
9 inch suspension lift
3 inch body lift
Dana 60 rear
Trac loc in rear
Dana 60 front axle
4.56 gears
40 inch Ground hawgs
8000lb warn winch
Road armor bumper
Kayline soft top
Factory roll bar
http://www.mudspace.com/muddrivermike
http://broncograveya...ord-bronco.html
#12
Posted 25 February 2010 - 10:46 PM
Sign In
Register
Help
Add Reply
MultiQuote
