Which hood to use
wilcom
Windsor, Ca.
I wanted to vent my stock hood with a hood scoop (forward facing or reverse) to get better air venting. Anyone have some ideas on what is out there. I would prefer to cut the existing hood and put on the scoop instead of buying a new one.
Broncoholics
Broncoholics
Washington State
Thats what I did. I cut up the hood and added a bubble scoop and drilled holes in the sides to let air out. Seems to work well and you can feel the heat pumping up and out.
W
wilcom
Windsor, Ca.
Ok, so that means that there are no vents in front i can see.....the side vents are great! Do you have rear vents? Also where did you get the bubble vent?
rcarm74
