97-03 F-150 solid axle conversion kit???
mudtruck
looking for help!!! i have a 2003 F-150 with a 6 inch lift and i want to do a front solid axle swap but im not sure where to start! i found a solid axle conversion kit on jeff's bronco graveyard but it looks like it's only the brackets. . . if anyone has any info about if it comes with an axle or new drive shaft or any other parts that would be awsome!!!! thanks!
muddrivermike
Texas Arp
They dont come with axles.Most likely you would get the front suspension,including axle,leaf springs and so on from an older or compatibile stright axle ford.The brackets are for mounting it all to the frame.
Utahstroke
