DIY Paint
Shwagy357
I have the next two weeks off (temporary layoff), so I was thinking what a perfect opportunitty to paint my Bronco. The only experience I have painting is when i sprayed epoxy primer on the Bronco three years ago. I am planning on painting in my basement in a makeshift booth using lots of plastic and a fan. I'm planning on painting the Bronco Pepper Grey Mettalic (44490). I went and saw my local paint supplier and he told me he could mix the color using ppg shopline paint. He told me I could get single stage or basecoat/clear coat. I think I want to buy the two stage cause it will last longer, does that sound right? He also told me that I would have to sand the old epoxy primer down and reprime it before painting.
I have a ampro HVLP spray gun from Advance. Is this okay? How important is the gun for spraying the base/clear coats?
I would greatly appreciate any input/advice/lessons learned you guys may have for me.
WOW..!
IMHO, That's a monumental task having never done this B/4
Cleanliness., & surface prep is the key., especially ANY area that silicone has touched.
Air., filters., & gun also important.
Metalics can be trickier.
Prime & finish products should be compatable.
Some req./prefer spraying on a 'sealer' prior to finish coat.
I would suggest an hr. or two in the library., then find a bodyshop mgr. who will let you hang around for a day or so.....
----- (You may end up going with a solid color acrylic enamel) ----
It could take 3 pages (front & back) to explain these proceedures....
It's an "art" & kinda like golf (or a frigid lady) ...in that you're never satisfied.
And..."fish-eyes" will be imbedded in your brain/nightmares ..!!
All-in-all it's a fun education... :D/
Good luck...!!
walkercreekbronco
It takes work, and attention to detail, but you can do it.
I did my first paint job in a dirt floor shed (over carpet) with plastic sheeting protecting my tools, wall, etc.
I used base/clearcoat. It's easier to fix flaws and sand a little dust out of clear coat. I used a bright Kawasaki green and it turned out pretty good (I get a lot of compliments on it). The metallic will probably be a lot harder to get right for a first time paint job.
You have to learn some time!
bigbluebronc
ca
I am rustoleum metalic blue, cardboard and tape, but my trucks ugly and cut and
I get California pin stipes(trees) every time I go out on the trails, easy touch up though haha, has stuck too the truck so far except a little on the hood for 4 years, 10 cans did it all but good lucky on your project, prep is the master key on all painting
Oldhenry1
