Ford Bronco Zone Early Bronco Classic FullSize Broncos: Softening Up Suspension - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
#1 User is offline   shutch4251
  • Bronco Newbie
  • Group: Members
  • Gender:Male
Posted 29 June 2009 - 02:06 PM
Have a 3.5 inch lift on 73 bronco. I understand that they are short body trucks and will buck a bit but the suspension seems to be really tight. Is there a way to soften up the ride for most street usage. I am wanting this truck to be used mainly on street for a restoration project vs rock crawler.. any thoughts?
This post has been edited by shutch4251: 29 June 2009 - 02:07 PM
73 w/ 302 3.5 lift 35" swampers and a whole lotta work to be done!
#2 User is offline   76Explorer
  • Bronco Maniac
  • PipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 29 June 2009 - 04:15 PM
Mine had the old "K Bar S" 3.5 inch lift on it when I brought her home, It made my back ache every time I drove it. I quickly replaced the front springs with "Deaver" progressive, and the rear leafs with "Deaver" 11 pack. It rides much better, but it's a Bronco, and will never ride like my Z71. Something you can check, the shackle bolts are not suppose to be tightened so much that it won't allow them to flex back and forth.
1976 Explorer Package
302 bored .040 over
C4 Auto W/Dana 20 J
Power Disk Brakes
Power Steering
Power Door Locks
Power Windows
Dana 44 3.50:1 Front
Ford 9" LS BB 3.50:1 Rear
BFG L/T 31x10.5x16s
Deaver 3 1/2" front coils
Deaver 3 1/2" 11 pack rear leafs
Stonecrusher Steering
Click the link below to see my gallery
http://broncozone.co...t...si&img=1589
#3 User is online   Bully Bob
  • TOP GUN
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
Posted 29 June 2009 - 04:37 PM
Ditto..
If you have progressive on the front., then most likely it's the rear.
If the rear is 5 pac.., then 11 pac will solve your prob.
Mine rides as smooth, or smoother than stock.
---Jeep recovery unit---
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
6 EB's (& 11 early Land Cruisers) referbished & sold..
#4 User is offline   MUZZALL
  • Bronco Mechanic
  • PipPipPipPip
  • Group: Members
  • Gender:Male
Posted 29 June 2009 - 08:47 PM
Which lift and shocks are you running?
68 Bronco HP 289, 5 1/2 BCB coils, 5 1/2 WH leafs, 4.10, D-44 disk, 9 in spool, 36" Iroks
#5 User is offline   S_bolt19
  • Bronco Commander
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Broncos and hockey are my hobbies, though some say obsessions. I also like to hunt, fish & 'wheel when ever possible.
Posted 01 July 2009 - 08:16 AM
A good set of shocks will do wonders for you. The springs are a big portion of the problem, no doubt, but you also have to look at your shocks. If you are running Rancho 5000 or comparable shock, you will have a very stiff and jolting ride. I switched to a set of the Rancho 9000 adjustable shocks with Cage coils & WH 11 pack leaf springs a while back. With my new set up, I can run washboard roads at 30 mph and barely feel them. But if you only do one or the other, change the springs first if it is an old lift (i.e. older than say 8-10 years) and then do the shocks. If the lift is newer, I highly recommend a top end shock. Rancho's 9000, Bilstein or Fox. They are expensive (Ranchos run about $100 per corner & Bilstein around there too) but for the ride quality, it is better than a $40 set of 5000 or ProComp 3000.
72 Daily Driver
- 5.0 EFI - NP435 - BB 9" 4.11 ARB Locked - D44 4.10 ARB Locked - Onboard Air - Front & Rear Disk -
- Yukon Axles - D & C Extreme Rock Bumpers - Hydro-boost - Stone Crusher Steering -
No honey, those were always on there.....
Motorstats.com Your Racing Headquarters
Page 1 of 1
Fast Reply
