Ford Bronco Zone Early Bronco Classic FullSize Broncos: are they the same frame? - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
are they the same frame? 460 swap
#1 User is offline   Foul Al
  • Bronco Maniac
  • PipPipPipPipPip
  • Group: Members
  • Gender:Male
Posted 24 June 2009 - 01:44 PM
hi all, i am about to buy an old f-350 with a fresh 460. it's sitting on an ambulance chasis. is this the same or similar enough to the 78'79' bronco frame to just outright swap it into the bronco? i have never considered an ambulance frame before? the donor is a 75, 76? ford. i have heard that the biggest thing to worry about is the exhaust manifold clearance and the radiator hoses. i am going to assume thati'll be using the 460 mounts. i think i have a 3'' or a 6'' suspension lift going under it as well. i might do 3'' body and 3'' susp.any tips, tricks or hints will be greatly appreciated.
F.Y.I. i'll be starting on the re-construction of the beast soon and will show pics on the way as well as any tricks or hints i can come up with on the way.
#2 User is offline   Yardape
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
Posted 25 June 2009 - 10:38 PM
should be an easy swap for you
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
Page 1 of 1
Fast Reply
