Ford Bronco Zone Early Bronco Classic FullSize Broncos: Performance Mods & CA Smog Laws - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
#1 User is offline   79BroncoProject
  • Bronco Newbie
  • Group: Members
  • Gender:Male
Posted 23 June 2009 - 09:33 AM
HELP! I'm trying to resurrect a '79 Bronco and am having problems figuring out what performance mods, if any, I can do legally here in CA. It has a stock 400 V-8 that runs well.
I know I can do a cam/valvetrain upgrade legally, and I think I can run headers as long as I keep the catalytic converter b/c it doesn't have an O2 sensor, but it looks like I'm stuck with the 2B carb. I can put on a dual plane manifold w/EGR but again, I think I'm stuck w/ the 2B carb.
Any advice or ideas? Are any of these mods worth it if I'm limited to the 2B carb?
Thanks!
#2 User is offline   bvteachey
  • It's Only Money, Right?
  • PipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
Posted 23 June 2009 - 05:42 PM
I used a Weiand Performance Plus Intake on my 79, and if i remember correctly there was an smog safe version of the manifold also. I used it to swtch over to a 4bbl. You could check into that on www.holley.com
79 Bronco, 84,000 original miles, worked 351M, Holley 600cfm 4bbl, My first paint job!
#3 User is offline   BRONCADONK
  • PipPipPip
  • Group: Members
  • Gender:Male
Posted 02 July 2009 - 08:47 PM
good luck, it took me almost two years to piece my bronco togather enough to pass smog. i finaly dropped it off at a smog repair shop, and $600 later it passed. only thing is they screwed my carb up and now it runs like poo. one thing i did do was install an edelbrock intake. it's smog legal as long as you use the egr adapter. once you pass you just pull it off and install your 4v carb. i plan on installing the 4v egr adapter and running an oem replacement holly. hopefuly i can slide pass the next smog tech. if not no harm, i'll just swap the old motorcrap back on till it passes again. maybe some day the peoples republic of california will bring back the 30 year rolling smog exemption and we can do all the cool mods we read and dream about. it's more likely that the tree huggers and bush lickers will force us to give up our old friends for boring disposable green cars. i dont know what will go first, our public lands, or our rigs?
1979 bronco ranger xlt trailer special. 400m stock except edelbrock performer 400 intake., c6, np205 (soon to be twin sticked), saginaw power steering pump coversion. 6 inch lift with 37 x 12.5 goodyear mt/r's.
#4 User is offline   78BroncHair
  • PipPipPip
  • Group: Members
  • Gender:Male
  • Interests:78 Bronco 351 4 inch lift 35 inch Mickey thompson MTZ on M/T Classic lock II <br /><br />54 Ford F100 6 inch chop with a 94 Thunderbird rack and pinion <br /><br />55 Ford F100 stock 223 6 cylinder and 3 on the column<br /><br />56 Ford F100 on a hand built chassis with 86 Chevy K5 blazer suspension and axles and a 383 stroker<br /><br />65 Ford Falcon with an 89 mustang HO 302 and a 5 speed<br /><br />
Posted 23 July 2009 - 01:33 AM
Do the bare minimum to smog it and then add performance parts. The state doesnt have to know!
78 bronco 4 inch rough country suspension lift, 35 inch M/T MTZ on M/T Classic Lock II wheels, edelbrock intake and 650CFM carb, 351M/C6, work in progress
21 Dodge hot rod 350 small block, 8' rear end, straight axle front end, 40 ford brakes all around, home built
53 Ford F100 stock 223 6 cylinder/ 3 speed overdrive, mild hot rod
95 Dodge 2500 4x4 cummins 5 speed leveling kit/35 BFG A/Ts, fuel plate/injectors/intake/exhaust/turbo coming soon!
56 Ford Country wagon 351c/C4 daily driver
Page 1 of 1
Fast Reply
