Ford Bronco Zone Early Bronco Classic FullSize Broncos: 78 bronco help! - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
78 bronco help! My bronco is dying!!!!
#1 User is offline   78BroncHair
  • It's Only Money, Right?
  • PipPipPip
  • Group: Members
  • Gender:Male
  • Interests:78 Bronco 351 4 inch lift 35 inch Mickey thompson MTZ on M/T Classic lock II <br /><br />54 Ford F100 6 inch chop with a 94 Thunderbird rack and pinion <br /><br />55 Ford F100 stock 223 6 cylinder and 3 on the column<br /><br />56 Ford F100 on a hand built chassis with 86 Chevy K5 blazer suspension and axles and a 383 stroker<br /><br />65 Ford Falcon with an 89 mustang HO 302 and a 5 speed<br /><br />
Posted 23 June 2009 - 02:47 AM
A couple months ago I bought a 78 bronco with a 351 and a 4 speed on a 4 inch rough country lift with 35 inch M/T MTZ tires on some M/T Classic lock rims. I ripped the rear axle completely out of the truck on the first day I got it. (loose U bolts) and I lost the transmission out of it a few weeks ago (which Im replacing with a C6 for now.) Does anyone know where I can find new rear springs (for a decent price) preferably where I dont have to run blocks anymore? The best price Ive come across is like 300 or so. and Im looking to either re build my 351 or swap in a 4bt cummins with a 5 speed or a 460 after I buy another truck to drive daily. Does anyone know what my best option is? And I want to mount a tach on my dash in the middle but my brother said he couldnt find anything solid under the dash to mount his tach to.. Anyone find out anything different? Also I eventually would like to run some 33x15.50 super swamper boggers for the mud and such (not every day tires, just to go WHEELIN with. Any ideas? And any other slick modifications anyone did to these trucks to make them more useful?
78 bronco 4 inch rough country suspension lift, 35 inch M/T MTZ on M/T Classic Lock II wheels, edelbrock intake and 650CFM carb, 351M/C6, work in progress
21 Dodge hot rod 350 small block, 8' rear end, straight axle front end, 40 ford brakes all around, home built
53 Ford F100 stock 223 6 cylinder/ 3 speed overdrive, mild hot rod
95 Dodge 2500 4x4 cummins 5 speed leveling kit/35 BFG A/Ts, fuel plate/injectors/intake/exhaust/turbo coming soon!
56 Ford Country wagon 351c/C4 daily driver
#2 User is offline   brandcole73
  • Bronco Mechanic
  • PipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Broncos, hunting, fishing, golfing, camping,
Posted 25 June 2009 - 08:30 PM
Check this link out.
http://www.pirate4x4...light=twinstick
I am replacing my c-6 right now and came across this to twin stick the transfer case. I'm going to do it to mine. I don't do much wheelin with mine, it's still too nice to bang up, but it would be cool to have! Don't think it doesn't leave pavement, I two track all the time! Just not real hard core stuff. I have a 3" suspension lift, new springs and coils. It was like that when I got it with 35" bfg MT's. They fit, but just barely. I put 33" AT's on it now.
I tell my son, don't worry about the other cars, but don't lean of the bronco!
1978 Bronco Custom, 400m
#3 User is offline   Yardape
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
Posted 25 June 2009 - 10:34 PM
I would go with the 460, its a direct bolt in swap. As easy as it gets. Any 3 inch wide spring from a 4wd ford truck will work. you can do a shackle flip which will give you about 4.5 inches lift with no blocks.
Lund Moonvisor
93 F350 4door 4wd 7.3 diesel huge beast of a truck
84 F150 351 H.O. C6 2wd (the parts getter)
'03 Expedition 5.4
BFG All Terrains
Superford.org
My Gallery
#4 User is offline   Johnny Reb
  • Bronco Maniac
  • PipPipPipPipPip
  • View blog
  • Group: Members
  • Gender:Male
Posted 30 November 2009 - 06:13 PM
How about mounting the tach on top of the dash? Take a screw out that holds the trim down near the padded dash? I did and its solid for it.
#5 User is offline   pimpa shrimp
  • Where's My Hammer!?!
  • Pip
  • Group: Members
  • Gender:Male
Posted 27 December 2009 - 04:00 PM
wear i mounted the tach in my 78 f150 and in my dads 73 f250 is just right of the radio besale in that open space. i put a 5" automeater with the shift light and it looks great
Page 1 of 1
Fast Reply
