Ford Bronco Zone Early Bronco Classic FullSize Broncos: No Power - Ford Bronco Zone Early Bronco Classic FullSize Broncos
Jump to content
Page 1 of 1
No Power
#1 User is offline   mtneerfan
  • Where's My Hammer!?!
  • Pip
  • Group: Members
  • Gender:Male
Posted 21 June 2009 - 11:49 AM
I pulled my 76 in to the garage and parked and now I have no power. It will not start and I have no power to the lights or anything else. I replaced the battery and the lights worked. I tried to start it and it turned over briefly and now the nothing works. Any ideas?
#2 User is offline   Bully Bob
  • Supreme Commander
  • PipPipPipPipPipPipPipPip
  • View gallery
  • Group: Members
  • Gender:Male
  • Interests:Hot women, 4x4'n, flying homebuilts -- or -- a nice Super Cub !
Posted 21 June 2009 - 02:30 PM
What else have you checked..?
For starters..,
Check batt. cable conn. at the batt. & the block (ground)
----" ----" -----" ----" --- at the solenoid & starter (pos.) & all connections on the solenoid.
1966 "U-13" Roadster...topless, doorless.
200 cu.in. I-6 with 250 head.
Full roll-cage, front.
70+ MPH cruise---15 MPG
---Jeep recovery unit---
6 EB's (& 11 early Land Cruisers) restored & sold..
#3 User is offline   mtneerfan
  • Pip
  • Group: Members
  • Gender:Male
Post icon  Posted 23 June 2009 - 06:11 PM
:lol:
For starters..,
All the cables were hooked up tight and the cables were in good shape. I cleaned some rust from the cable that run from the battery to the solenoid with some sandpaper and everything is working fine. I thought for sure it was something alot more complicated. Thanks.
#4 User is offline   Bully Bob
  • Supreme Commander
  • View gallery
  • Group: Members
  • Gender:Male
Posted 24 June 2009 - 12:50 PM
"I cleaned some rust from the cable that run from the battery to the solenoid with some sandpaper and (now)everything is working fine. I thought for sure it was something alot more complicated. Thanks."
---- You're welcome.., & as a side note;
A good percentage of the problems on older rigs can be solved by that very serv./maint. proceedure, on several wiring connections, from headlights to tail-lights & most everything in-between.
This post has been edited by Bully Bob: 25 June 2009 - 06:09 PM
Page 1 of 1
Fast Reply
